Newbee
Newbee
Hi there.
Just introducing myself as a new Firestorm owner. Bike hasnt run for a few years. Purchased this weekend. Now runs and fully serviced. Needs clutch and brakes bleeding. A 'T' plate model with 17000 on the clock. Will be nice when done....thank you.
Re: Newbee
This was taken 6 years ago. Still looks pretty much the same just dirty and alloy bits are tarnished...watch this space...thank you.
Re: Newbee
Hi there again...
while the bike is i bits and being prepped and cleaned etc i was going to fit manual cam chain tensioners and a news yoke and straight bars. Can anyone suggest a link on here where to get info from and where to buy the best ones...thanks again
Re: Newbee
Kreiger, APE, Bazza and Ade Whitmarsh's CCT's > viewtopic.php?f=31&t=22720
Bike Maintenance and Upgrades/Modifications > viewtopic.php?f=23&t=31345#p304638
- alanfjones1411
Re: Newbee
Welcome to the club mate
Re: Newbee
Hello and welcome
Re: Newbee
Started the strip down. Rear wheel off and polised...rear brake caliper stripped and cleaned...swingarm next which has been painted...badly...
Re: Newbee
The second photo is what the Firestorm shares the workshop with...05 Fazer 1000 and a Honda NX650 Dominator...
Re: Newbee
Hi there...todays jobs. Strip the crappy paint off the swingarm and clean the mountian of chainlube off everything and make new brackets fot the cans instead of those kitchen utensils that are on there.
Re: Newbee
Just a little question all of you. Got the bike running on Sunday. Now starts on very little or no choke. Ticks over at about 1500rpm. Give it some throttle and let the throttle off and it has started to backfire a little. Any help greatly received...cheers
Re: Newbee
Air leak on exhaust system.
Or possibly carbs not seated properly.
- alanfjones1411
