Fault?
NZSpokes
Fault?
Post by NZSpokes »
My bike has just developed a fault.
Seems to be running on one and the front header is cold. Jets are clear, have blown out the carbs, slides seem fine. Strong spark, seems to be charging. Fuel delivery is strong.
It just idles but when I open the throttle it dies. :confused
Run the battery flat with so much starting. Am wondering if the battery is dying.
Open to ideas.
bigtwinthing
Re: Fault?
Post by bigtwinthing »
It could be a coil breaking down, Plug, or Fueling etc. does it slowly rev up, or stall only if you open it quickly? you need to give us a bit more info.
NZSpokes
Re: Fault?
Post by NZSpokes »
bigtwinthing wrote:It could be a coil breaking down, Plug, or Fueling etc. does it slowly rev up, or stall only if you open it quickly? you need to give us a bit more info.
Soon as I open the throttle it dies.
NZSpokes
Re: Fault?
Post by NZSpokes »
Starting to think more this is a battery dying. Will fit a different one in the morning.
Re: Fault?
It wouldn't hurt to check what voltage you're getting at the battery terminals when the bike is running, plus see how far down the volts drop when starting :?:
macdee
Re: Fault?
Post by macdee »
petcock ?
pipes on the wrong way ?
VTR Phoenix
Re: Fault?
Post by VTR Phoenix »
Have you checked your air hoses and made sure a carb hasn't popped off? Pulling in too much air?
Re: Fault?
Check reg rec first.
Over voltage will cause a coil to stop sparking.
Undo drain screw in front Carb to see if there's fuel in the bowl.
If there's fuel, then it'll be spark.
Swap cools over to see if the rear pipe is then cold.
At least you know which pot it is.
Varastorm
Re: Fault?
Post by Varastorm »
I'd be tempted to put some petrol in a little garden hand pump sprayer (atomiser) & spray it into the snorkel or remove the air box lid when its idling.
If the revs rise more than you can get it to rev by turning throttle grip, you have an issue with the fuel supply. If its the same, its electrical.
When running the bike with the tank removed, I have/use an old washing up liquid container with the bottom cut away & the nozzle pushed into the fuel pipe. Keep an eye on the level & I don't put too much fuel in case it spills out.
I always have a couple of wet/damp towels & a fire extinguisher close to hand also.
I found out the hard way, No amount of screaming & bashing a fire with an empty tool bag puts the flames out :wtf: :thumbup:
Re: Fault?
Varastorm wrote: I found out the hard way, No amount of screaming & bashing a fire with an empty tool bag puts the flames out :wtf: :thumbup:
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
NZSpokes
Re: Fault?
Post by NZSpokes »
macdee wrote:petcock ?
Was running fine. New fault. No hoses moved. Checked delivery with a hose and its flowing very well.
NZSpokes
Re: Fault?
Post by NZSpokes »
tony.mon wrote:Check reg rec first.
Cheers, yes have checked the front bowl and fuel there.
Its got a mosfet? Reg but will check it today with a fresh battery. Bit early here to run the VTR at 5k rpm. Sunday morning and all.
NZSpokes
Re: Fault?
Post by NZSpokes »
Confirmed battery fault. Charging at just under 14v at 5k rpm so charging system look fine. Charged battery and it runs as normal.
Time to shop for a new battery.
Re: Fault?
I have a couple of good lead acid/gel types spare if you want to pop round? :lol:
Glad it's sorted out though.
NZSpokes
Re: Fault?
Post by NZSpokes »
tony.mon wrote:I have a couple of good lead acid/gel types spare if you want to pop round? :lol:
Not sure my current battery would last that ride mate. :lol:
Current, get it? :clap:
