Manual Cam Chain Tensioner Installation Guide (MCCT's)
Re: Manual Cam Chain Tensioner Installation Guide (MCCT's)
Damn! Don't despair mate, as previously mentioned there's enough spares amongst us to get you rolling again, you may just need to invest some more time into it.
Jamie
cheers jamoi. shes already been carted away on a trailer looking all sad for itself. should get the report this week and see if its worth fixing the donkey.Jamoi wrote:Damn! Don't despair mate, as previously mentioned there's enough spares amongst us to get you rolling again, you may just need to invest some more time into it.
Oh sh1t
Hope it's salvageable
Sent from my SM-G850F using Tapatalk
They're always salvageable.
Just depends on how many bits you need.
Ask if you end up needing bits or help.
Man down, but we ain't leaving him behind....
cheers boys i have to say its good to see help is at hand
Update?
Which cct's did you fit?
Mid cheshire
Too old really!
Too old really!
Roly wrote:Update?
PMd you.
alls good with the big girl now.
Hi Guys,
I'm wondering what the end of the cam chain tensioner runs against, as the tensioners I have are just bare metal on the end, does it press against something else before touching the chain? I presume it would, just wanted to be sure.
Mark
Mark
VTR1000 Firestorm in yellow, lubbly jubbly.
Life's only Fun when your doing a Ton.
Hopefully you have tensioner blades (no.3) installed. Do you have manuals or auto CCTs installed? As OEM auto tensioners also have metal caps (no. 6) on the end of the tensioner.Taz69 wrote:Hi Guys,
Mark
http://www.bike-parts-honda.com/pieces- ... STORM.html
Hi mate,
That helps clear things up, at the mo I have auto's installed my plan is to put the manuals I got from Ade.
I presume then the blades will be there.
Thanks
Mark
Thanks
Mark
Be very worried if you don't!I presume then the blades will be there.
Wicky wrote:Be very worried if you don't!I presume then the blades will be there.
Thanks, I'm much happier now.
1 thing though, can I get tho the front over etc without removing the carbs? just by removing the fairing and cover etc?
Some peple do , some don't it all depends if you want to get to the front head cam covers to directly measure the front tension/ or just do the finger tight back ¼ turn. Read and reread the installation guide till you're familiar with the procedure. Don't rush, have all the tools and parts required to hand inc cable ties for restraining the cam chain (just in case) and some silicone thread lock etc.Taz69 wrote:Wicky wrote:Be very worried if you don't!I presume then the blades will be there.
You don't need to remove the fairing - but you will need to take off at minimum the tank (make a note of where all the hoses go!) and airbox (careful with the screws and reattaching hose) and rear cam cover. While you're in deep its a good opportunity to fit a vaccum take-off plug and hose on the front pot to make carb balancing later on an easy job.
You can remove the front cam cover without removing the carbs by going in from the front, but IMHO it's much better to remove the carbs, it's a lot less fiddly. Just take some photo's as you go as they may come in handy on refitting. You don't have to remove the coolant hose on the carbs, you can with patience move the carbs about enough without,
You don't need to remove the fairing - but you will need to take off at minimum the tank (make a note of where all the hoses go!) and airbox (careful with the screws and reattaching hose) and rear cam cover. While you're in deep its a good opportunity to fit a vaccum take-off plug and hose on the front pot to make carb balancing later on an easy job.[/quote]
Thanks, I have the tank, airbox off, I have already fitted the front vacuum when I balanced the carbs a couple of years ago, btw if I did remove the carbs and had them sonically cleaned do they need resetting up?
Thanks
Thanks
