How do you know
roger64
How do you know
Post by roger64 »
Lets say you buy a second hand bike from a dealer how do you know if there is a product like Slime tube sealant in your tyres. :?:
With out doing a destructive test ie driving over nails or slashing your tyres :thumbdown:
I only ask this as I tried balancing the rear tyre and the heavy point keeps moving. :sad2
Wanted yellow donor bike
Re: How do you know
Take valve cap up and press valve to let a little bit of air out?? If green stuff comes out then you know.
roger64
Re: How do you know
Post by roger64 »
I let quite a bit of air out and no green stuff came out 8O . The front wheel has only one heavy spot that it goes past then rolls back to, while the back has about 3 different spots where it passes then rolls back too ?
Re: How do you know
Slime sticks to the rim as well as the tyre.
I would suggest pressing the valve in for a good 30 seconds when the valve is at the 12 o'clock position and letting the air blast out at full strength.
If not you may have to let all the air out and break the bead and physically have a look.
On the up side, slime is supposed to be self balancing so if the wheal was balanced before it won't need doing again so do you really need to balance the wheel?
Re: How do you know
I wouldnt get to worried aslong as its not the front wheel... :thumbup:
