Fao travis and/or Mike
Re: Fao travis and/or Mike
Are these for sale or not
- spikenipple
They will be once I've got the standard pipes back on. Consider the sale 'on hold' for now. I'll update my For Sale post
Edit: I've got a short day at work today so I'll have a crack at it this afternoon.
Could you not have emailed to say what's happening after putting them on for sale and Chris giving you emailspikenipple wrote:I'm having trouble fitting the standard exhausts back onto my Firestorm as they don't seem to line up properly with the original pipes for some reason.
I'm working out whether I need to wiggle the downpipes around to get everything lined back up, and in the process make sure that the cans & link pipes I have are designed to fit standard pipes before I sell them.
The last thing I want is to sell the lot, for the buyer to then find out they don't fit normal headers.
- spikenipple
I'm awfully sorry that I didn't get in touch with you the moment I received the message
Perhaps I was busy, rather than ignoring you out of spite.
Very poor Spike that took you nearly 2 hrs to reply...spikenipple wrote:I'm awfully sorry that I didn't get in touch with you the moment I received the message
- spikenipple
Don't you start
Oh I've already had a ''piss off'' from Mr Angry...Stands back & awaits incoming...spikenipple wrote:Don't you start
- bazzashadow
may be you should post like ebay does
" this seller is away until"
Maybe admin has an itchy trigger finger that is ready to press the button
Everything good is bad
Everything bad is good
Sorry Sir...Jazzscot wrote:Maybe admin has an itchy trigger finger that is ready to press the button
It's a shame to read posts from someone so rude.
All you have posted about since joining is - What can I get out of the forum?
Try putting in to the community before you expect anything out of it.
Here for a good time, not a long time.
Jamie
Cupasoup would of smashed it days ago lolJazzscot wrote:Maybe admin has an itchy trigger finger that is ready to press the button
Tried that reasoning...maybe not as eloquant mind...All I got was ''piss off'' for my troubles...Jamoi wrote:It's a shame to read posts from someone so rude.
How you doin' Jamie ?
You recoverd from all that bending over from when you joined...?
''Try putting out for the community before you expect anything out of it....'' You forgot to add bringing your own lube helps a lot...
Try 3-4 days.....it's just that I'm used to when someone sells something they usually answer quite quickly cause they want it sold, if that's me being impatient very sorry
- spikenipple
I put it up for sale primarily to members of the forum that have been here long enough to contribute, and with 50+ posts.
If I wanted contact from anyone else I would've put some other contact details on the advert.
I'm deeply sorry to tell you that I spent this afternoon taking advantage of the (seemingly rare) sunshine and did some gardening, and didn't spend any time trying to sort the exhausts out.
I hope to get down the garage tomorrow evening, so watch this space.
