The other night I went into my workshop (shed) and saw a petrol stain on the Rh side frame rail directly under the tank. I felt up under that bside of the tank and was able to wipe reddish residue away.
So I removed the tank ('03 model) expecting to see a leak around where the hoses fitted onto the underside of the tank or around the fuel sender unit. But nothing as seen below. These pics show areas where there is definitely no leakage present.
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100212_zpsszqu6dek.jpg)
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100209_zpshan9nl3m.jpg)
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100192_zpsueijcm7p.jpg)
The following pics show the area where there is fuel residue where the tanks mounts at the rear to the frame.
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100214_zpsiwevo9fr.jpg)
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100216_zpswmgyhkyq.jpg)
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100186_zpsypnsluib.jpg)
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100190_zpsmxd68psl.jpg)
There is more residue on this area on the LH side under the bar. Not so much on the actual tank as seen below.
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100208_zps1banrupw.jpg)
![Image](http://i226.photobucket.com/albums/dd105/donclifton/VTR1000%20Fuel%20Tank%20Leak/P1100207_zpscg9u3uca.jpg)
If anyone has had a fuel leak from their tank their experience in where this leak may be coming from would be helpful. I am thinking it is coming maybe from under the welds of the rear tank mounting points at the rear of the tank.
Do these late model tanks have any common areas where they are prone to leak?
Any help from those more experienced in this stuff than me will be most appreciated.
I need a solution to the problem as well as pinpointing where the leak is coming from.
Thanks for any and all help offered.
