Front cct went recently and I've just been looking at the timing marks etc and reading some of the guides, but Im a bit old so would appreciate enlightenment
Rear head timing spot on, whats the procedure from here timing the front? Its defo skipped on the front so marks will be inaccurate so im going to need to retime it.
Could someone point me to an idiots guide please?
It could be the drugs
resetting timing after cct failure help
Mid cheshire
Too old really!
Too old really!
Re: resetting timing after cct failure help
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
Great, so rear head timing done, so, rotate 450 degrees anti clockwise, then front marks should be facing away from each other? Cam lobes? With timing marks lined with head flat? I honest got brain fog............ Im not usually so slow!
Mid cheshire
Too old really!
Too old really!
Looks like you have done it now but here it is anyway.
http://www.vtr1000.org/phpBB3/viewtopic ... 83#p264316
FYI if timing from the front to the rear it's only 270°
