evening all
evening all
Evening all just a quick hello, my names Ben and I've had my storm since September last year which I bought of my brother love it to bits apart from the chain tensioner breaking on me 2 weeks ago
Re: evening all
welcome to the forum ben, sorry to hear about the failed cct, no matter how much we say fit mcct's, failures still happen, I hope you get it fixed and back on the road asap.....
p.s don't forget to mention your location, a fellow member might be just around the corner and willing to help.
Re: evening all
Howya Ben. Have had CCT go and it's not nice. Hope you shut her off before you bent a couple of valves
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
Re: evening all
Hello and welcome tho if you joined in September you would of been told about the ccts :ball kick:
Oh well you know now .
Have you fixed it yet ?
- carmanbikes
Re: evening all
Hello and welcome Ben, Your in the right place loads of good advice on here, Good luck with it and hope your soon out riding again
Re: evening all
Welcome aboard buddy
Shame about the failure
Re: evening all
Hi all fitted new cct on Friday evening and she sounds like a bag of spanners still unfortunately, checked compression all seems fine time to strip down again for a closer inspection
Re: evening all
Before you strip the bike too far, did you check that the cam sprockets and crank timing marks are aligned?
Re: evening all
Tell us where you are Ben - there is help out there
Re: evening all
Checked all the timing marks and all lined up well, im based in surrey and my brother is a mechanic so he's helping me with the rebuild, but he's just had a baby so pinning him down is a hard job at the moment
Re: evening all
Happened to me TWICE. First time I ended up with 2 bent valves and cracked valve seats
From what your saying it sounds just the same
Re: evening all
Sorry to hear the news about your bike fella. Welcome to the club and good luck with the rebuild.
Re: evening all
Welcome aboard Benmilkybarben wrote:Hi all fitted new cct on Friday evening and she sounds like a bag of spanners still unfortunately, checked compression all seems fine time to strip down again for a closer inspection
I'm sorry to hear about your CCT woes.
If the compression is good then you shouldn't have bent any valves.
Re: evening all
welcome to the team Ben, hope you get it fixed and there is not too much damage
