Rectifier wiring help for mosfet
Re: Rectifier wiring help for mosfet
dudehog wrote:Is it ok to use the original top bolt location and put the recti there? Do these get hot enough to damage the fairing plastics? I did think about making an aluminium plate so shift it further up to the wider part of the fairing. Obviously I'll rehouse the indicator relay somewhere else but that's another story.
Also thanks again for all the help. It's really appreciated. If I do make a plate up I'll put up a pic. I may also put the earth wire that sits on the recti bolt straight to the battery. :Mexican Wave:
Before you chop any wires...make sure you have the correct crimping tool...The new crimps you get may be square like the originals, a standard crimping tool will not work as it is a round profile.
How ever all is not lost...you can un-pick the crimped wires from the connector block. Use a small flat blade screwdriver, go in from the back & you will see a small tang, hold this down & you can pull the wire out of the block complete with attached crimp.
These will fit straight onto the new R/R but will not hold in the new 'sub' connector blocks...the new crimps in the kit have a different tang which locks into the block, which you then plug into the R/R...
Yep they is big...lesss heat so plastics should be OK. One bolt should be fine or drill a new hole & use a nut & bolt.
Indi relay I just moved on to the top of the undertray just inside the sub frame rail.
dudehog
Post by dudehog »
I don't suppose anyone could provide a link to the right crimping tool on ebay could they? The cheaper the better as it's only going to be used this one time, but I do want to do it properly.
dudehog wrote:I don't suppose anyone could provide a link to the right crimping tool on ebay could they? The cheaper the better as it's only going to be used this one time, but I do want to do it properly.
http://www.rapidonline.com
http://www.rapidonline.com/tools-equipm ... al-86-4512
http://www.rapidonline.com/tools-equipm ... aws-305950
http://www.vtr1000.org/phpBB3/viewtopic ... 80#p375492
dudehog
Post by dudehog »
Awesome Now if I can find those on ebay :thumbup:
dudehog
Post by dudehog »
http://www.ebay.co.uk/itm/416110-Mini-M ... 418f04bdb0
This'll be ok won't it? Would prefer one like the chunky one but I'm only using it once :)
At that price if it works it's a good un, and will be useful for other folk. Otherwise I can lend you mine.
You haven't got to make up a mounting plate, I just preffered to use two fixing points. No the MOSFET unit doesn't get very hot at all, only warm I'd say.
This is how it looks fitted with only using one original fixing hole:
And with a mounting plate with two fixing holes:-
Nice pics Chris and a very neat job. :thumbup:
And I shall add if one wants to be particular about things then some Thermal compound paste/grease could also be added between the plate and the back of the body on the R/R.
firestorm_al
Post by firestorm_al »
cybercarl wrote:And I shall add if one wants to be particular about things then some Thermal compound paste/grease could also be added between the plate and the back of the body on the R/R.
That's exactly whay I did when I had the R/R problems on my old FireStorm.
Al.
darkember
Post by darkember »
Just need the mosfet when i find a decent priced one and i'll be good to go as well
cybercarl wrote:Nice pics Chris and a very neat job. :thumbup:
Cheers Carl :thumbup:
dudehog
Post by dudehog »
Just saw those picture. I've been doing something similar whilst waiting for my heat shrink to turn up.
dudehog
Post by dudehog »
well it's all back together and running a cool 14.25 volts :)
a MASSIVE thank you to all of you for your comments an pics. They've helped a lot :)
:clap:
Excellent - great to hear you've finished the job - Did the ebay bargain price crimps work okay?
dudehog wrote:well it's all back together and running a cool 14.25 volts :)
:clap:
