Bent valves.
Yorkie boy
Re: Bent valves.
Post by Yorkie boy »
Cheers Carl. It's not too bad but I might give it a bit of a tickle - good to know that I won't need rubber gloves and breathing apparatus :D
Re: Bent valves.
A brass wire wheel in a drill makes the job an easy one. Do it with the valves dropped in to avoid damaging the seats.
That's for the heads, the pistons can be scraped and wire brushed with the rotary brush as well, it sort of polishes the surface, less stuff can stick thereafter.
Yorkie boy
Re: Bent valves.
Well, here she is (if the photo's loaded ok) - stripped down and cleaned up, waiting on new exhaust valves. Fingers crossed, this is as bad as it gets :crazy:
Re: Bent valves.
That's not bad....this is bad. :lol:
Yorkie boy
Re: Bent valves.
Nah, that's not bad ....... this is BAD !!!
Half a camshaft-holder bolt, no prizes for guessing where the other half ended up! Managed to extract the bolt and now waiting on a replacement, but well worth the wait :lol:
Yorkie boy
Re: Bent valves.
Replace bolt finally arrived. Bolt in, valve cover on. Oil-cooler fastened, radiator on and coolant filled.
Then, holding my breath, I fired her up. Brilliant, no death-rattles, just a beautiful v-twin thump.
A huge thanks to everyone who helped keep me sane and the guidance that kept the confusion at bay - Carl, you played a blinder :thumbup:
For someone who had only ever changed the oil it's been emotional - fingers crossed the weather will hold.
The smile has returned. :D
:beer:
Re: Bent valves.
That's fantastic news. Now you can get out and ride. :thumbup:
Re: Bent valves.
Bugger, I won't be able to buy the wreckage for £200.
Delivered.
Good jarb!
Now pull it all apart again and get tuning, now you know how easy it all is....
BrianC
Re: Bent valves. You in Bolton Yorkie ???
Post by BrianC »
If you are still in Bolton I may ask for your help!!!!
May be buying a storm and at a minimum cct s will need doing
Get in touch if you can
Briancrook at blueyonder.co.uk
Storms over Lancs !!'m
Re: Bent valves.
Brian I've just changed your email address and put "at" instead of "@" for your security. Anybody wanting to send an email to you should realise they need to put the correct "@" in themselves without any spaces in between,
BrianC
Re: Bent valves.
Post by BrianC »
Ta Chris
Brian
