Chain Tensioners
jaytee
Chain Tensioners
Post by jaytee »
Hello All
This is my first post in any forum let alone this one so please forgive any newbey mistakes :roll:
I have recently acquired a P reg Firstorm and have noticed i fairly loud ticking noise coming from the rear cylinder and being as there is a lot of talk about the CCT's on this site was wondering if there is any advice on changing them as they are the standard Honda type.
Cheers J
Re: Chain Tensioners
welcome to the forum, its not as scary as you imagine... with the exception of Mac, Tony.mon, KevL, Lloydie, Virt, CKennedy, Jamie, BTT, Bannannaman, Macdee, CyberCarl, Agent P, the rest of the people on here are great guys. :roll: :D
regarding the CCT, look in the workshop knowledgebase section and all will be revealed.
add your location and you might find that someone local can help out or have a listen if needed
Oi :-( . Hello and welcome
carmanbikes
Post by carmanbikes »
Hello and welcome :thumbup:
darkember
Post by darkember »
welcomes :wave: :wave:
bigtwinthing
Post by bigtwinthing »
Hello and welcome, ( and I've just noticed iam in the list) !!!
Welcome aboard, we're a good bunch ( and I'm not on the scary list) :thumbup:
Greetings
Head over to > http://www.vtr1000.org/phpBB3/viewtopic ... 23&t=31345 and have a good read about imploding CCTs, R/Rs etc *** Read Me for New Members ***
lumpyv
Post by lumpyv »
hello buddy :thumbup:
where in the world are you ? (I cant help with your cct,s, im just a nosy b8stard :lol: ) somebody may be near you though
It's usually the front tensioner that fails so if yours is the rear it may be that your pancaking a bit after reading bits.
Welcome :beer:
adewhitmarsh
Post by adewhitmarsh »
Hi, if you contact me I can help you with manual ccts.cheers Ade
Welcome to the club mate
Hvornum
Post by Hvornum »
Replaced my CCT's a week ago.
There's a GREAT manual for it here: Manual Cam Chain Tensioner Installation Guide (MCCT's) (it's the same process as the automatic OEM stuff.. Took about 3-4h in total to swap everything. Be CAREFUL when tightening any exterior bolts putting things back together, i broke a bolt to the crankcase cover without any applied force what so ever.. They're just mean to hold things in place not to actually tighten things up)
And yes, definitely change the CCT's BEFORE any real damage is done.
You're probably lucky enough so that the camshafts haven't jumped any teeth minimizing the damage done.
jaytee
Post by jaytee »
Thanks for all the replies chaps, i'll look at the info and get it sorted asap. im from crowborough east sussex by the way.
i see there is a member who adapts the existing ccts, does he still do it ?
jaytee wrote:Thanks for all the replies chaps, i'll look at the info and get it sorted asap. im from crowborough east sussex by the way.
Yep, that's Bazza696. He does an exchange service, you buy some and send the old ones back after fitting.
They're a lot better than other manuals, in my opinion, because the front one pokes up over the radiator hose and is easy to get at to set up and adjust.
I fitted a pair of Ade Whitmarsh's to a member's bike last week, and they were a right pain. Plus Ade uses 15mm dome nuts and lock nuts- most spanner sets don't include 15mm AF....
Bazza's are better, and cheaper.
Just my opinion...
I'll give Bazza a nudge for you, as you won't be able to PM him until you have 50 posts.
