Which chain & sprockets do you use, and why...
I have to make a decision about which C&S's to put on the 'storm, and I can't decide on which manufacturer to use....AFAM or Tsubaki for the chain, and OE sprockets, or renthal ones.
Which do you all use, and what would you recommend?
Ta
Ed
Ta
Ed
Re: Which chain & sprockets do you use, and why...
Just fitted Tsubaki and Renthal to mine mate but obviously can't comment or recommend at this stage!
I use steel sprockets back and front for longevity and a good brand xring
Always renthal, not a bad life span and look nice
So is there much different between AFAM and Tsubaki, or is an X-ring chain, an X-ring chain!?!
Stock Honda steel front sprocket, Renthal rear and DID X-ring chain. With my scotoiler I am starting my forth year with them on and I do an average of 3000 miles a year.
Might change them all again cause I have nearly polished the gold anodise off the chain and rear sprocket![Shocked 8O](./images/smilies/icon_eek.gif)
Afam front and back with heavy duty xring chain with 10000 mile guarantee ![beer :beer:](./images/smilies/beer.gif)
- Pete.L
I've tried loads of different makes over the years and I can honestly say there is not a lot of difference between the manufactures.
What I have noticed is, if you buy a cheep chain they don't last very long. Go for heavy duty or extra heavy duty and then don't skimp on cheep sprockets. Get the highest carbon rating sprocket you can.
Its normally the sprocket wearing away which causes wear on your chain so if you are going to change the chain do the sprockets too
DID X-Ring, JT steel sprockets (15/44), scot-oiler. - changed after 18,000 miles wear was not excessive and only adjusted a couple of times apart from tyre changes etc.
replaced the rear JT with a supersrox sprocket as it was shinier but else all the same again.
Max
![Image](http://i27.photobucket.com/albums/c156/wjames/babies2.jpg)
Still running on originals @ 28,000miles. Thought I'd want new this season but think will go till next year.
Theres A Hare in The Turnips.
pretty sure mine is on originals at 17k.
I think the scottoiler helps..
- Pete.L
+1Max wrote:DID X-Ring, JT steel sprockets (15/44), scot-oile
I've used that combo too and found it gave me the best chain life
