Ooo look - another n00b to the site!
Re: Ooo look - another n00b to the site!
It's red, but will need stuff doing to it as it's been sat up for 18 months with only the occasional fire-up. This is my list of things to do, with no doubt 'additions' to it!
New battery
New C&S
New tyres
Manual CCTs
Drain/replace all fluids
New pads
New bearings (dependent on condition/wear)
New air filter
New spark plugs
New cables
New clutch line (think the old one is the original rubber line)
Check/replace reg/rec
If you knowledge-able lot know anything else I've missed then shout!
Ed
New battery
New C&S
New tyres
Manual CCTs
New pads
New air filter
New spark plugs
New cables
Ed
check the starter motor connection, peel back the rubber boot, if corroded, give it a clean and change the nut, then a big dollop of grease under the rubber boot, jobs a good'un
Thanks agentpineapple
Welcome aboard Ed
You've covered the two main things (rectifier and CCT's)
Hi there Ted nice looking Bike you got there.
BTW is your shed zero gravity
"It may be yellow but it ain't no chicken"
hello there Ted .
SHED, Magnum??!!!!
I'll have you know, that there is a garage of the finest order! Hahaha!!
Spent the last 2 weeks on and off painting it, installing new lighting and flooring while I was waiting the iminant arrival of the 'storm!!
Welcome to the forum. I see you haven't got the original anniversary cans on the bike. Does it still have some of the anniversary bits left on her.
I believe I'm the 6th owner, cybercarl - bought it off my mate - who always had these exhausts on it...
What were the Anniversary cans like, and what other bits (apart from seat cowl) did it come with?
nice bike and the garage is looking very OCD............but why are you still keeping that broken fork?
AMCQ46 wrote:...but why are you still keeping that broken fork?
Three pronged fork......shouldn't you be riding a Trident?....Oh Yea Welcome to the forum Ted, and good luck with the red projectile
The anniversary had Remus cans, Harris rearsets, proflex rear shock amongst other bit's I will have forgotten.
Steering damper, carbon yoke cover and tank cap cover and that's as much as I can remember.amongst other bit's I will have forgotten.
