Headlight bulb upgrade!
Can anyone advise me what the largest wattage headlight bulb is I can run without any problems and major mods? :?
Re: Headlight bulb upgrade!
Stick to H4 -60/55 W - unless you put a ceramic bulb holder in (to replace standard meltable OEM placcy/nylon one) / Eager Beaver Relay kit.
Wicky wrote:Stick to H4 -60/55 W - unless you put a ceramic bulb holder in (to replace standard meltable OEM placcy/nylon one) / Eager Beaver Relay kit.
Cheers Wicky :thumbup: Where would the best place be to source all that? :?
http://www.easternbeaver.com/Main/Wirin ... _kits.html
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
With all that don't push it with silly wattage bulbs as things can still melt!
Wicky wrote:http://www.easternbeaver.com/Main/Wirin ... _kits.html
Nice one :thumbup: , was thinking along the lines of 100w? What do you think and will light lens be ok?
no you will get condensation build up and it will ruin the lens (i know as it happened to me ) just used the normal buld and fit a relay kit . or fit a projector + HID kit
Careful if you have it on main beam too long…
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=16761
I have a 55/100 with relay kit in mine, no problems with that as it is normal rated on dip beam
mik_str
Post by mik_str »
AMCQ46 wrote:I have a 55/100 with relay kit in mine, no problems with that as it is normal rated on dip beam
here too... works like a charm!
Is that with ceramic holder?
Shauned71
Post by Shauned71 »
I'm running with a 100/55 so I have a better high beam when needed. Fitted 6 months ago, plugged straight in and no issues.
No, I bought the normal relay kit with plastic holder, I didn't spot the ceramic one back then when I did the conversion. No sign of problems on the connector last time I had the fairing off
Cheers lads :D a few options to think about there :thumbup:
Saintsman27
Post by Saintsman27 »
A member posted these bulbs earlier in the year .. cheap enough.
http://www.ebay.co.uk/itm/230763060244? ... 1423.l2649
Saintsman27 wrote:A member posted these bulbs earlier in the year .. cheap enough.
Wonder if anyone has tried them? Not got any faith in Chinese products :?
