And as for AP... you could have explained all that. Havent you learnt anything yet.
you beat me to it carlos, I was just about to type out the same thing word for word, honest I was guvnor.......cybercarl wrote:And I forgot to say....Well done Virt.![]()
And as for AP... you could have explained all that. Havent you learnt anything yet.![]()
darkember wrote:Hi Fordstorm & welcome. We met at the bus station last weekend![]()
As you will see this place will answer all you questions. Definitely your timing is out by 180 degrees. When you do the manual tensioners that is when you will need to reset the timing.
Follow the following link to the T & do not deviate, in your case you would be wise to strip the bike back so that both cam covers are removed to enable the correct timing to be achieved. If you need a hand I'm only down the road. Just take your time.![]()
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=28583
While you at TDC on the compression stroke, check the cam sprocket alignment marks to see if the chain has jumped at all, but also check the valve clearances while your there. If there are excess clearances more than within spec then there may be some bent valves. But I'm wondering if there has been a previous failure and the previous owner/garage has tried to mask over this by adjusting the clearances rather than change any bent valves. Your description "round on a squeeky wheel" concerns me.sounds like a hamster is living in there going round on a squeeky wheel
darkember don't suppose you can dig that cap out for me please? I have replaced ccts but have put an alankey straight through the crank cap cover and out the other side so my bike isn't going nowhere atmdarkember wrote:If you need a replacement cap I have one floating around in my parts bucket
Good news on the rattle. I have dug the cap out ready for you to collect. I'll be home most evenings after 8pm. Drop me a line when you think you'l be dropping by.fordstorm wrote:darkember don't suppose you can dig that cap out for me please? I have replaced ccts but have put an alankey straight through the crank cap cover and out the other side so my bike isn't going nowhere atmdarkember wrote:If you need a replacement cap I have one floating around in my parts bucketgood news is the horrible rattle has gone
That is good news I agree,fordstorm wrote:darkember wrote: good news is the horrible rattle has gone
