changed the entire wiring loom, my bike now has a datatool alarm......
a little tip for anyone changing their wiring, work from the back to the front, especially if you have a big alarm box on the rear...
Sorted...agentpineapple wrote:changed the entire wiring loom, my bike now has a datatool alarm......
a little tip for anyone changing their wiring loom, get Carl to do it, it's much easier...
Balanced carbs on the storm and the fazer, neither needed any adjustment, but neither had been done in my ownership. Glad I know they are both set up right now.
Changed the oil and filter on the V-Strom. Then swapped the speed sensor over on the VTR! Another exciting day! Too wet to go out and play!
Fitted vtr.org stickers,look proper tidy in chrome . Thanks to Pat
have you got the system 3 one off carl i sold him then?agentpineapple wrote:changed the entire wiring loom, my bike now has a datatool alarm......
Yes mate.have you got the system 3 one off carl i sold him then?
I just fitted a dark tint Fabbri screen.
THIS POST IS WORTH LOADS WITH NO PICS
Use you imagination
Last update in 08-2013...a little bit 'bling bling' for my 'golden girl'
Lloydie i forgot to give you the hose attachment for the quick drain oil valve
PM your address when you see this and ill pop it in the post just seen it when i went in the garage and went oh bugger
Will do thanks Seb let me know how much postage is and ill cover it :-)seb421 wrote:Lloydie i forgot to give you the hose attachment for the quick drain oil valve
Don't let BSM see you saying thatcoinneach wrote: went daft with the stick on carbon vinyl
I know thinks its his idea I stole for the lightSteve6088 wrote:Don't let BSM see you saying thatcoinneach wrote: went daft with the stick on carbon vinyl
Today I cut the yellow faded plastic lenses off of my GT250M clocks and replaced them with some glass ones from an old cx clock set. Also had to evict numerous families of spiders (sorry Frank!) that had taken up residence in the clocks.
I have also zinc plated various bits and bobs of brightwork from the Suzi. A very satisfying process turning bits of rusty metal into shiney bits to be bolted back on.
glad to hear you have seen the light.........no pun intended.....coinneach wrote:I know thinks its his idea I stole for the lightSteve6088 wrote:Don't let BSM see you saying thatcoinneach wrote: went daft with the stick on carbon vinyl
