Front vac take off
Moderator: VTRDark
Front vac take off
Does anyone have a front vac take off? Want to get my carbs balanced but in need of one of these. Could do with it by Sunday this week.
Anyone able to help before I have to order a set from a shop? Would rather give a few quid to one of you lot
Re: Front vac take off
As a quick fix, get you out of trouble, any one who has an old engine can take their rear one out. I know this as I went to take the brass one out of 'Ole Red to swap on to Drooper & It just mangled the screw head being only very thin brass. The one on the rear cylinder is steel & has a small hex base. It came out no worries.
So if any one can help & lend Chris one for the weekend I'm sure he'll send it back when done, & be forever in your debt, or buy you a tea or something.
Failing that get some from Carbtune , they only sell packs of four, fit it & sell the others on here.
Mac
Mac
Or keep for other bits you may need some hose for, like a Scotoiler or something. Carbtune are very quick with delivery http://www.carbtune.co.uk/carbaccs.html I recommend them. They also do the brass connectors. IIRC I think it's 5mm that is required for the Storm.Failing that get some from Carbtune , they only sell packs of four, fit it & sell the others on here.
Good point mac I will have a look on the seized engine to see if I can get it off
- Redthunder
Don't forget to leave a vacuum tube (blanked off) on front cylinder to allow for easier balancing in future!
Thanks for the reminder.
Also ck have you got a t piece on the rear vac pipe ?
If not you will need one too
Halfords sell them 5mm T piece .
I should have enough vac pipe for it to be left on your bike but I will check later to make sure .
Oh bring a few cable tie too I've ran out !
I've just looked in the garage and I have every thing needed so bring yourself and the vtr and we'll get it done :-)
was it a little dry the last time ?AMCQ46 wrote:remember the lubrication before inserting the tube
lloydie wrote:was it a little dry the last time ?AMCQ46 wrote:remember the lubrication before inserting the tube
Scarily relevant
getting jealous YMV
Damnit it's the YMV thing again
Nope, I have enough KY gel here to drown a whale
im no sperm whale im fat freeVirt wrote:Damnit it's the YMV thing again
oh and thanks for the updated avatar
