almost immediately after it started twatting it down the bike was running like sh1t missing and spluttering, same symptoms as when the storms front drain hole is blocked and the water collects and then boils up in the recess and coil and makes it run like sh1t
Had to put my hazards on and ride down the hard shoulder till i got it off the motorway.
left the bike running for a while when i got to work to help it generate some heat and dry out whatever rain had got where it shouldn't have been
fired up okay 6 hours later for the ride home, again in the rain but only light rain
got home took the seats off to find the ECU and plugs all wet, dried it all out with a hairdryer and some spray and paper towels
easy to see how this happens when you look at the poor design
Rain gets down the back of the seat and then where the join is gets in the recess and then drops directly onto either plug, yep well done on that one suzuki!
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163722_zps46fdf7cd.jpg)
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163727_zps127dff22.jpg)
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163736_zpsb15a3584.jpg)
Note the visible light here... this is okay if your riding and no traffic as your front wheel wont whip up spray in here but get anywhere near a car or truck and its piss wet in here which coats the batt and ecu etc
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163908_zps51b65c76.jpg)
So much spray gets in it covers the pillion area and inside of the indicators and other gubbins and also gets into the tool bay area
and then runs down the centre, yep you guessed it back to the ecu!
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163745_zpsc0dd45d4.jpg)
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163817_zps1cda4c1b.jpg)
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163823_zpscaaf3fd4.jpg)
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_163830_zpsaa93001f.jpg)
Also replaced those bolts from a previous grab rail or somthing that was fitted with some Titanium ones, these now grip in the thread unlike the junk that was in that you could pull up without screwing
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_025138_zps417d4d11.jpg)
![Image](http://i58.photobucket.com/albums/g257/seb421/20130510_025220_zps9e9d38aa.jpg)
