New Bellypan
Rampant Lion
New Bellypan
Post by Rampant Lion »
Fitted a belly pan this weekend. Bought off ebay in scruffy black. Had it colour matched to the bike. Real pleased with the end result.
Had: CB125. Benelli 250. Yamaha YDS7.Kawasaki Z400. Kawasaki Z650c. Kawasaki Z650B1. Kawasaki Z1300.Suzuki Bandit 1200. BMW R1100R. TDM 850 (2 off). Suzuki Bandit 1200. BMW R1100RT. Yamaha XT600.
Now: VTR 98 Storm in lovely silver....
Re: New Bellypan
Looks nice. Good job fella. :thumbup:
Re: New Bellypan
Yep looks great :Thumbup:
whitestorm pete
Re: New Bellypan
Post by whitestorm pete »
nice clean look mate :thumbup:
If sh1t were money you would be worth a fortune
lumpyv
Re: New Bellypan
Post by lumpyv »
:thumbup: that shape with the gap looks best with your handlebar setup I think :thumbup:
do you know what make it is ?
Re: New Bellypan
Good job R/L, IMHO that works very well 8)
Re: New Bellypan
I think Rampant wins the award for best Storm Tourer. Nice looking bike. :thumbup:
Rampant Lion
Re: New Bellypan
thanks for all the comments. No idea of the make of the belly pan. If I find out, I'll post the make. Cheers guys. :D
bluestoesonnose
Re: New Bellypan
Post by bluestoesonnose »
I really like that, I think the gap between the fairing and the belly pan all ways looks good on the Storm
Re: New Bellypan
like it, it sets the bike off well.
but every time I look at the photo I keep thinking it was designed to sit 2" higher, so the oil sight level glass is lined up with the matching flat on the belly pan [and the flat is drilled out obviously].
It looks good where it is, but if it was designed to sit higher you might have ground clearance problems especially when you have all your touring boxes filled.........I say this because I managed to get my Moriwaki belly pan on the ground when riding 2 up after I got a weight related rear spring fitted
bluestoesonnose
Re: New Bellypan
I think the flat on the belly pan is for a mounting bolt and you may have to cut the pan about as it does look close to the exhaust in the photo.
I agree about ground clearance though, it does look a little low, but it could be the angle of the shot, etc, etc
Rampant Lion
Re: New Bellypan
I'll have a look at the fitting again at the weekend when I'm home. It's fitted using three points, a bolt on the right side which uses the original bracket and two long bolts from beneath which go into the rear and front sump holes on the left side. All at present line up just right. If it was to sit higher at the back then the pre drilled holes would not match. No harm in having another wee look anyway. Could be that the pan is designed to suit more than one bike with different fixings. Bought second hand, so unsure really. Thanks again guys...
captainoi666
Re: New Bellypan
Post by captainoi666 »
bluestoesonnose wrote:I really like that, I think the gap between the fairing and the belly pan all ways looks good on the Storm
Yeah, I also like the gap between fairing and belly pan. Many motorcycles have a full fairing. The visible parts of the engine between fairing and belly pan makes the Storm something special. I don't like this huge belly pans. It minimize the special character of the Storm.
I've got almost the same belly pan as Rampant Lion has. There were some problems with overheating from the exhaust pipes, but fixed it with heat protective foil.
Cheers Buk (and sorry for my poor english :roll: )
bluestoesonnose
Re: New Bellypan
I kike the idea of the heat protective foil. Just fitted a belly pan to my partners Monster (http://www.ebay.co.uk/itm/D0250-BELLY-P ... 483b0b086c) which whilst built like a tank does need a little help around the exhaust. I also like the mesh, all good ideas.
BigVeeGrin
Re: New Bellypan
Post by BigVeeGrin »
and I do!
Captain - what make of pan is the one on yous?
