Hi folks,
I'm looking to drop a tooth on my front sprocket, and need to remove a link from my chain.
I have a fairly new tsubaki alpha x ring chain, and can't find anywhere to buy a rivet link from.
If anyone has any info, i'd really appreciate it.
Thanks, Steve.
Tsubaki alpha soft link
Re: Tsubaki alpha soft link
Thanks,
Am i to understand from this that a new link doesn't necessarily have to be from the same manufacturer as the original chain ?![Confused :confused](./images/smilies/confused.gif)
I wouldn't and this site which sells them also advises not to mix links with different chains - found using google and key words tsubaki rivet link
http://www.intobikes.co.uk/products/000 ... Rivet-Link
Thanks very much Wicky,
product ordered !![Very Happy :D](./images/smilies/icon_biggrin.gif)
product ordered !
- benny hedges
are you sure you need to remove a link?????Steve H wrote:Hi folks,
Thanks, Steve.
i went down to a 14 for a while and still used the standard length chain.
with a standard rear and a 15T front you dont need to shorten the chain
have a look at http://www.gearingcommander.com and it will give you the number of links for any sprocket combo
That what I was thinking. I wouldn't bother personally. The only advantage would be a tad more adjustment before it reaches the maximum wear marks.are you sure you need to remove a link?????
Been thinking about this today, i don't want to make unnecessary work for myself.
i will try the sprocket on its own first.
Thanks for your input guys !
