good to see the bike getting used
what is it like riding a hardtail in the wet ?
nearly finished. a quick update....
Re: nearly finished. a quick update....
wet is ok, pot holes jarr a bit tho!
never been much of a rossi in the wet, anyways. gettin old, falling off hurts these days....
When subjected to an electrical voltage of at least 50 volts, a cat's tail always points toward the north.
Bloody hell mate you've had some luck with everything fitting so well. Did you resolve the problem with the oil spitting back out the breather. I look forward to seeing the new paint job. I like the way those twin pipes look as well. They should suit the bike.
it's on my 'to do' list....cybercarl wrote: Did you resolve the problem with the oil spitting back out the breather.
