test vid
Re: test vid
[youtube][/youtube]://www.youtube.com/watch?v=_PNsPoMlisw&plcp[youtube][/youtube]
Re: test vid
[youtube]www.youtube.com/watch?v=_PNsPoMlisw&=youtu.be[/youtube]
Re: test vid
[youtube][/youtube]
I just removed the from the end.
so you have where the video is
+ the video
I just removed the
Code: Select all
&feature=youtu.be
Code: Select all
http://www.youtube.com/watch?
Code: Select all
v=_PNsPoMlisw
Re: test vid
<< it should look like this but with [youtube]insert link here[/youtube]
“Only by constantly developing your insight and knowledge can you fulfil your responsibility to ride safely and effectivelyâ€
Re: test vid
Well done. The problem is all the youtube URL's are slightly different so you need to look where they place the feature& and the player. The only bit you need to keep is the watch& plus the underscore and number for you video. Hope that makes sense. And it's usually best to use the address (URL) in the browser bar rather than the one under the share.
You will get the hang of it after a few, but every once in a while there will be a link (URL) that catches me out.
- dragonback
Re: test vid
wondered how you had it all in super slo mo then i clocked the colour of the mudguard nuff said cough cough
DOES THIS RAG SMELL LIKE CHLOROFORM TO YOU ?
- dragonback
Re: test vid
only ribbing ya ! where did you have the camera btw ive tried various places but it always comes loose , gonna tape it to my leg next time
Re: test vid
ill just keep comeing back to this thread untill i get it spot on every timecybercarl wrote:Well done. The problem is all the youtube URL's are slightly different so you need to look where they place the feature& and the player. The only bit you need to keep is the watch& plus the underscore and number for you video. Hope that makes sense. And it's usually best to use the address (URL) in the browser bar rather than the one under the share.
Re: test vid
in front of the indicator on the right hand side.dragonback wrote:only ribbing ya ! where did you have the camera btw ive tried various places but it always comes loose , gonna tape it to my leg next time
http://www.actioncameras.co.uk/drift-hd ... tAodDEsA3Q
type in baron10 and you get 10 percent off total price
But I have orderd some more brackets off ebay and i am makeing some fail safes incase the sticky stuff becomes unsticky
