Caps Stuck in Brake Calipers!
Tried to do a full strip of brakes/seals on Weds (in prep for fitting HEL hoses) and whilst all going well with removing calipers from the bike, the problem was met when I couldn't for the life of me get the external cap from the calipers that covers the allen bolt to remove pads. Bugger!
Tried the sliding scale of - force! (though starting to deform so stopped), release spray, heat. No joy!!
Same for both front calipers, rear was difficult but released in the end - Im so annoyed with whoever did them last - but I also suspect salt ingress/corrosion!
Any ideas? As next plan will be to drill out !!!!
KriegerCCTs,HEL oil lines,+4 advancer,+1/-1 sprockets,6mm spacer,CBR1k Sidestand,'07 R1 R/R,HyperPro springs F&R,Pipe Werx SL Carbons,Oxford sports hot grips,Mori style belly
Immediate plans:Clean it!
Re: Caps Stuck in Brake Calipers!
+1 Impact driver if the callipers are off it's simple.
Impact drive; yep, thought of it but with the small deformation with a screwdriver I stopped myself. It will do no harm I guess if next step is drilling!!
Once they're out - replace (+ some copper slip) with these stainless steel versions:
or
http://www.ebay.co.uk/itm/STAINLESS-STE ... 500wt_1081
or
Wish I'd thought of that b8stard when I did mine...got the mop bucket of love full of stainless steel fixings etcWicky wrote:Once they're out - replace (+ some copper slip) with these stainless steel versions:
or
cordless hammer drill with appropriate socket??
Good idea but I think a screwdriver attachment on drill will slip, deforming the head even more. Impact driver is the safest bet as it's designed for this very purpose.cordless hammer drill with appropriate socket??
Right tool for the job and all that.
B ,F and I , thats me !cybercarl wrote:Good idea but I think a screwdriver attachment on drill will slip, deforming the head even more. Impact driver is the safest bet as it's designed for this very purpose.cordless hammer drill with appropriate socket??
I'm not very good with acronyms.B ,F and I , thats me !
Bottom Fitting Insert fitted with Brute Force and Ignorance
