Belly Pan Brackets
- bluestoesonnose
Belly Pan Brackets
Does anyone know where I can get aftermarket belly pan brackets from?
Not too sure of the belly pan type
Re: Belly Pan Brackets
Post up a photo, or direct us to a photo of your make of belly pan and we might be able to help
- bluestoesonnose
Looks like the one in your picture
If you're definitely sure it's the same as mine below then it's a Powerbronze product.bluestoesonnose wrote:Looks like the one in your picture
Funnily enough having a tidy and I found the fitting instructions for a Powerbronze belly pan/lowers, which lists all the bits & bobs required and plans for the 3 brackets which would be easy to fabricate.
http://f.cl.ly/items/2H3Y3E2A181t3s3V1T ... nzeVTR.pdf
You'll probably also need to line part of the inside of the belly pan with heat insulation/reflective blanket to protect it from the exhaust. Someone here had a shed load of the stuff going cheap.
- bluestoesonnose
Nope not quite like your's
Photos to come
Photos to come
- bluestoesonnose
Ok it needs a litle bit of work but...
- babysitter
The Belly pan looks like a Skidmarx Fairing Lowers type you can get the fitting brackets from them
http://www.skidmarx.co.uk/product.php?id_product=30106
Harley Davidson Roadking 1690 / Harley Davidson 1200 Sportster
54 Honda Varadero XL1000 / Honda Firestorm Red,/ BSA B40WD Trials,
/Audi TT 225 / Foard Transit T300/ VW Touareg
He could be on to somthing there, if you look closly the skidmarx has the bracket that goes across at the front. Note the bit cut out to view the oil level window. Also the pan bluey has is fiberglass is the Skidmarx fiberglass.
Oh and here is the picture he was refering to Sirch
from here http://www.haymouth.co.uk/phpBB3/viewto ... an#p125733
check out this thread
http://www.haymouth.co.uk/phpBB3/viewto ... =8&t=23503
Hope that helps
Hope that helps
That's Warby's bike and I bought the belly pan from him inc. fittings. No idea of the make.
- bluestoesonnose
Hi, many thanks, it does look like a skidmarx item, I'll give them a call later
Blues
Blues
- bluestoesonnose
Brackets ordered from Skidmarx, £20.00 + £3.00 p&P
You learn something new everyday I hadn't realised Skidmarx were doing the lower fairings as well as the bellypans. Good info babysitterbabysitter wrote:The Belly pan looks like a Skidmarx Fairing Lowers type you can get the fitting brackets from them
