swing arm
macfreebe
swing arm
Post by macfreebe »
Hi there any tips on how to refurb the swing arm thanks
mark r
Re: swing arm
Post by mark r »
do what i did when the weld went on the brake calliper bracket, and brace it while its off the bike .
tinysmall
Re: swing arm
Post by tinysmall »
macfreebe wrote:Hi there any tips on how to refurb the swing arm thanks
Take it off the bike, clean everything with paraffin then sort the bearings and collars. Pretty easy job and makes a difference.
Never argue with idiots. They drag you down to their level then beat you with experience!
macfreebe
Re: swing arm
Post by macfreebe »
Thanks guys but i meen the look of the swing arm as i tried cleaning it and using auto solve on it but the marks dont come of and it looks dirty
Re: swing arm
Take it right off, strip all the bearings out & get it down to your local powder coaters.
Get it back & rebuild using all new bearings, seals & various spacers n bolts + loads of grease.
Make re-lube & through check over part of your annual strip down & spruce up.
tattoo
Re: swing arm
Post by tattoo »
you'll never polish it by hand,you need a bench grinder and polishing mops to get it all blingy but tbh once you've done it it'll take some keeping up with...macV2 has right idea...powdercoat it...
macfreebe
Re: swing arm
Post by macfreebe »
Cheers guys what colour do you think i was thinking black but not sure any of you guys got it done?
tattoo
Re: swing arm
Post by tattoo »
i'm sure i've read that bigspanishmarty powder coated his frame and swingarm black but you don't have to have yours done black,you can have it coated silver,blue,red even pink if that floats your boat...it's all about daring to be different and being individual.
Stormin Ben
Re: swing arm
Post by Stormin Ben »
I went with satin black and am really pleased with it
But its not a very good one!
Re: swing arm
the options are endless!!!!!!!!!!
tattoo
Re: swing arm
Post by tattoo »
i don't want to pull my bike to bits altogether...but looking at that blue frame i might just be tempted
macfreebe
Re: swing arm
Post by macfreebe »
Thats seriously dam good looking bikes there with a lot of work and money gone into them i think i,ll go with the black
