Hello
Can anyone help please i got an annoying misfire only when it rains, ive tried and front fender extender and ive cleared the drainage hole by the front plug new spark plugs.
Any ideas would be grateful
Thanks
Misfire when raining
Re: Misfire when raining
shrek493 wrote:Hello
Thanks
check the ht lead and plug cap for any sort of corrosion or cracking
wd40 sprayed on the area will help until you find the problem
jambo
- stormingjoe
- Contact:
check your leads and coils for shorting etc, and loose wires, an old trick of mine was to find a very dark place fire it up then see if you can see any 'sparks', if not, give it a good soaking with a hose and go dark again, fire it up and you should see any sparks. try to avoid any sprays on ht side of electrics ie wd40/acf/duck oil these can create problems and make things worse.
- stormingjoe
- Contact:
had a pajero, missed when doing a bit of off-roading going through puddles(only 4 foot deep as i didnt have the snorkel fitted), found an arc on a lead, cleaned and dried then sprayed wd all over, next puddle miss again lift bonnet now arcing along wd destroyed 160£ worth of ignition coil had to be towed back. this was the last time i used wd for this purpose, sprays are ok on low energy sytems of old would not recommend on high energy modern ignitions, acf affected my HiD lighting as well, as this spray appears to be conductive. In days gone by i would have recommended them as a cure all, got a lot of my customers out of a prob at the road side many a time. nowadays not too sure as modern systems are getting pretty delicate as to energy irregularities and shorting.
