Howdy peeps
Howdy peeps
Been on the VTR yahoo listy type thing for years, thought I'd get round to joining another forum.
Have a 1999 Storm 125K on clock and the bugger has just eaten a CCT, as I was surrounded by lorries and it was pissing down (plus earplugs) thought the noise was a lorry, and continued wrenching the throttle as it lost power!! not the sharpest pencil in the box! Probably not economic to repair, but I shall have to see what horrors await I guess.
Bit of a hassle as it is my everyday transport - cover 25k+ a year.
cheers
cheers
Re: Howdy peeps
Allreet buddy, bad luck with the CCT but its not the end of the world and hopefully wont be too costly. Good luck.
- stormingjoe
- Contact:
Re: Howdy peeps
HELLO chap, get on eblag couple of engines up for grabs on there at mo!
Re: Howdy peeps
Thanks chaps - shall have a look
Re: Howdy peeps
Welcome aboard grimley59
Sorry too hear about the CCT failure etc. I'm impressed with your Storm's mileage (125K) WOW
If you're able to do the work yourself it won't be to expensive.
Cheers,
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
Cheers,
- bikerpiker
Re: Howdy peeps
Welome mate
125,000 miles
..well done
Shame about the cct ,...to give us an idea of cct failure ,could you tell us how many miles you've put on the bike yourself, and how many cct's you have replaced over those miles![Smile :)](./images/smilies/icon_smile.gif)
125,000 miles
Stevie
Re: Howdy peeps
I've had the bike since new. It was generally well looked after ie serviced when it should be, until 37k miles. I then moved from London to near Peterborough, but all my work is in London and the southeast (stupid move really), so I have put 90k on it in the last 3 years. Hasn't been serviced and has had about 4 oil changes
First CCT failure, bike has had a replacement 2nd hand starter motor and I have had 2 rear suspendy linkage failures - latest one I fitted with grease nipples. Been through 2 R/R and the clutch slave cylinder has developed a slow leak. Had one electrical breakdown at night, of course, due to wire chaffing through under the instruments and against the fairing bracket. Guess it has earnt its keep.
cheers
cheers
- Pete.L
Re: Howdy peeps
Not a bad service history considering the mileage and the use, Well done.
Will you be doing the engine rebuild yourself or putting it into a garage for the work?
Re: Howdy peeps
Hopefully getting it sorted this weekend - CCT's arrived today. Fingers crossed the valves are ok.
cheers
cheers
Re: Howdy peeps
Bugger - both inlet valves are bent and I assume the exhaust will be the same, whipping off the head tomorrow, its vodka frenzy time now
Re: Howdy peeps
Not wishing to raise your hopes too much, but the exhaust valves may be OKgrimley59 wrote:Bugger - both inlet valves are bent and I assume the exhaust will be the same, whipping off the head tomorrow, its vodka frenzy time now
Re: Howdy peeps
I've picked up a used cylinder head off ebay - cant be bothered to dismantle all the fiddly bits. Hopefully that will be a straight bolt on.
folks
Re: Howdy peeps
That's one way around it I guessgrimley59 wrote:![]()
folks
I hope all goes well
- LotusSevenMan
Re: Howdy peeps
That bike doesn't owe you a thing with that mileage/record!! Good stuff. Makes the rest of us summer wussers only feel a bit ashamed.
Still, good luck with the rebuild. Piston's OK I take it?
LSM
LSM
Re: Howdy peeps
Hopefully not piston broke like mePiston's OK I take it?
![Image](http://www.zen55986.zen.co.uk/Uploads/Motorcycle_line.gif)
