Changing Spark plugs
Rincewind
Post by Rincewind »
since the success of sorting the front brakes, i've decided to change the plugs
so once again i bow to the fount of your collective knowledge
How do i get at them? which ones are they best replaced with???
i think i can manage the removal and refitting, just dunno how to get at the little buggers
thanks
Never argue with an idiot, they will drag you down to their level and beat you with experience.
bluesman
Post by bluesman »
I think best ones are NGK Iridium. I am cheapskate - I went for NGK Platinum.
NGK Platinum for Storm
DPR9EVX-9
NGK Iridium for Storm
DPR9EIX-9
Stormin Ben
Post by Stormin Ben »
Front one:
Get down on your knees by the front wheel
Remove the plug lead
Remove plug using decent plug spanner (or if you are desperate, the one in the toolkit!)
Set plug gap as per the manual -worth taking your time and getting spot on
Remove little nipply thing from the end of the new spark plug end (I think :?: -check the old one as you take it off)
Fit new plug into spark plug socket (decent ones have a rubber insert to grip the end, cheap nasty Honda toolkit ones don't)
See Bens top tip below
Rear one
Remove seat
Remove rear tank bolt (horizontal 10mm bolt)
Use n-shaped allen key bracket from toolkit (if its missing a brick or block of wood will work fine) to prop up the rear of the tank
Remove plug lead
Remove plug etc
Bens top tip
The spark plug should screw virtually all the way in using just your fingers on the tool.
If you need to put any force on it, DON'T.
Instead remove plug and try again. It is VERY easy to cross-thread the plug and if you then force it home you will shag the head
But its not a very good one!
Max
Post by Max »
I just put ngk iridium ones in mine and I'm sure its using a lot less fuel.
Max
ips
Post by ips »
If you don’t have a descent spark plug socket will the rubber insert.
Then use a short length of hose pipe that the spark plug end fits in and use that to initially screw the spark plug in. Can also be used for taking them out. I found an old washing machine hose was perfect.
Growing old is mandatory; growing up is optional.
Stormin Ben
Until the Mrs noticed the puddle of water on the kitchen floor the next time she used the washing machine!! :lol:
ips
Post by ips »
Got married, didn't need the washing machine any more :P
Rincewind
Post by Rincewind »
right, had a crack at this last night
assembled all the various spark plug sockets, of which none seem to fit :?
any idea what size i need to purchase???
alan
spark plug
Post by alan »
I think its an 18mil i did valve clearances last week and sure it was this i had the same problem couldnt find one to fit then found a t bar socket.Hacked it up with hacksaw put a socket joint on so i could use a straight bar and ratchet.Even the one in the bikes shite tool kit doesnt fit!!
Rincewind
Post by Rincewind »
bike tool kit doesn't exist!!! so that ain't a problem
will have another crack this weekend,
Re: spark plug
alan wrote:I think its an 18mil i did valve clearances last week and sure it was this i had the same problem couldnt find one to fit then found a t bar socket.Hacked it up with hacksaw put a socket joint on so i could use a straight bar and ratchet.Even the one in the bikes shite tool kit doesnt fit!!
I think you are right when you say a 18mm Alan, but that's as in spanner size I think :!:
In actual size of spark plug spanner that will be a 12mm :!:
Sounds confusing doesn't it :?: that's what I thought :wink:
Don't ask me why but I think that is correct :!:
alan
18 mil
Post by alan »
Er yes youve confused me Chris :lol:
Rincewind
Post by Rincewind »
you're confused........ :?
Your best bet is to take one of the spark plugs with you, to the shop so you can make sure you come away with the right one :!:
Rincewind
Post by Rincewind »
but its the getting them out thats the problem!!! :wink:
