Hi I've owned my firestorm for about a year now, this winter ill be stripping it down and repainting it, but since I've owned it the seat has always rubbed the tank edge and some times slips under the tank, is this common or has the previous owner moved something or could it be an aftermarket seat?
Thank you in advance
Seat rubbing on tank
Re: Seat rubbing on tank
on my previous storm i had one of them clear tank protectors but i dont think the seat would fit under the tank. maybe your seat is cut down or something. post a pic maybe
Have you removed the seat at all to see if there is something missing, bent, or out of alignment?Vtrcameron wrote: ↑Mon Oct 19, 2020 6:37 am Hi I've owned my firestorm for about a year now, this winter ill be stripping it down and repainting it, but since I've owned it the seat has always rubbed the tank edge and some times slips under the tank, is this common or has the previous owner moved something or could it be an aftermarket seat?
I'd have a look there and use the pdf service manual to help you find anything missing or maybe broken.
Pictures would do justice too.
No, that doesn't sound like a common problem.Vtrcameron wrote: ↑Mon Oct 19, 2020 6:37 am Hi I've owned my firestorm for about a year now, this winter ill be stripping it down and repainting it, but since I've owned it the seat has always rubbed the tank edge and some times slips under the tank, is this common or has the previous owner moved something or could it be an aftermarket seat?
Has the seat still got the standard cover on it I wonder, may be an aftermarket one has been fitted, or someone had trimmed the seat down to accommodate short legs.
I agree some photo's could help in sorting out your problem,
Thank you for your replies, I have been working away and will post a picture when I get home, plan on removing seat to investigate more soon.
Thank you
Thank you
Hi im sorry its been a while business picked up so been busy, I've attached some photos of the seat hope helps if need others let me know unsure what it could be.
Thank you again
Ross
Thank you again
Ross
There should be some rubber trim along the edge of the tank...
No.14... https://www.ronayers.com/oemparts/a/hon ... /fuel-tank
You should be able to pick up some u-shaped trim from a motor factors that will do the job.
Thank you will pick some up,
