CBR600 Stick Coil - does polarity matter?
StewartR
Post by StewartR »
Hi,
I am fitting CBR600 stick coils and wonder if the polarity matters when wiring the CBR connectors on to Firestorm.
Cheers,
Stewart.
Re: CBR600 Stick Coil - does polarity matter?
Yes.
The spark should jump from the centre electrode out to the ground terminal.
If you put voltage to ground, then expect a spark to occur, you may have to wait a while.
Just follow the colour coding from the donor bike's wiring diagram.
E.Marquez
Post by E.Marquez »
StewartR wrote: Mon Feb 10, 2020 9:00 pm Hi,
Cheers,
Stewart.
Yes black with white trace is the ground, and common to both coils. The other wire (colored not black) is the hot one..
Id also mention I make custom plug and play cables for this MOD, but you UK guys are cheap as chips :lol:
So I figured Id just tell you the answer for free :D
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
