High rise handle bars
Just rode my mates with conversion can this be done without chopping fairing
Re: High rise handle bars
do you mean fitting flat bars in place of clip-ons, or are you talking about fitting higher clip-ons?
not tried the clip on route, but I thought Suzuki SV650 clip-ons gave a higher position and didn't need cut, and you can also space your stock bars up the fork legs by more than 20mm without cutting.
for flat bars, I used Ultra low bend bars and needed to cut a very small amount off the rear/bottom lip, and you cant actually notice it. ... witt try and post a picture later
you could also go for true flat bars [called drag bars] that have no upward bend, but I haven't tried them so cant say if they will avoid cutting.
Thanks for the reply so sv650 clip ons fit the VTRs forks?
Yes to SV bars. And yes to drag bars, but I had to add a bit to the lock stops. Just stuck on with contact.
Yes, Renthal Ultra Low handlebars can be fitted with the right handlebar-risers and steering lock stops fitted so you don't need to trim the fairing.Tickymonks wrote: ↑Wed Oct 23, 2019 3:03 pm Just rode my mates with conversion can this be done without chopping fairing
You can read all about my conversion here:- viewtopic.php?f=31&t=41099&p=447870
- MaroonMachine
Or if you are just after the bars being higher get a set of adjustable bars like Apex .
There are other brands available I'm sure however I forget their names.
South Coast
New South Wales
Australia
New South Wales
Australia
Thanks for all replies gives me a few options
I tried drag style bars before going with the Renthal bars. I mocked up a set of handlebars using copper pipe (take note not for riding the bike, just checking to see if they would work before buying some), I found due to no rise in the bars the banjo bolts of the original OEM clutch and front brake master cylinders both fouled the fork legs (stanchions), the part which sits above the top yoke. Probably a longer/wider style of drag bars may have worked.
IIRC using a CB400 top yoke means you have to drop the forks down the yokes so the handlebars can be positioned above the fork stanchions to a degree. This is counter productive in getting the best from the suspension by dropping the forks down the yokes, it won't handle as well as it could, more noticeable if you are running after market suspension,
- MaroonMachine
Mine,came with the cb400 top yoke.It handles ok and I don't get any problems in th twisters or straights
can you send a photo of the yokes from the side showing the amount of fork leg that is sticking out above the top of the yoke, and how close it gets to the bars?MaroonMachine wrote: ↑Fri Oct 25, 2019 4:49 am Mine,came with the cb400 top yoke.It handles ok and I don't get any problems in th twisters or straights
will help us understand if the CB400 yoke is compromised as Chris thinks. is you are pushing the forks down to miss the bars, then this will slow down the steering .......... most of us have gone the other way by both putting spacer under rear shock to jack the back end up AND drop the front end by moving the forks up through the yokes.
That's goodMaroonMachine wrote: ↑Fri Oct 25, 2019 4:49 am Mine,came with the cb400 top yoke.It handles ok and I don't get any problems in th twisters or straights
That is a very good idea Al, a side on photo would be very helpful,AMCQ46 wrote: ↑Fri Oct 25, 2019 10:54 amcan you send a photo of the yokes from the side showing the amount of fork leg that is sticking out above the top of the yoke, and how close it gets to the bars?MaroonMachine wrote: ↑Fri Oct 25, 2019 4:49 am Mine,came with the cb400 top yoke.It handles ok and I don't get any problems in th twisters or straights
will help us understand if the CB400 yoke is compromised as Chris thinks. If you are pushing the forks down to miss the bars, then this will slow down the steering .......... most of us have gone the other way by both putting spacer under rear shock to jack the back end up AND drop the front end by moving the forks up through the yokes.
- MaroonMachine
You also got any close up side photos showing the forks and yoke.
