idle problem
2nd Ranger BN
idle problem
Post by 2nd Ranger BN »
my vtr1000f pulsate when it idle, I have put in a stage two jet kit, it did start right after but it pulsates between 1100 to 1400. it runs great when I am on the road and it doesn't die when I am idle it just pulsates. I have an adjustable jet needle I think I might have them up to high. What are the thoughts on this
Re: idle problem
That's tricky.
it can depend on so many factors. It could be rich or lean. What type of of pipe/airfilter you are running. Is the choke sitting fully in.
Have a read through here and see if you can glean some idea's viewtopic.php?f=31&t=14214
Re: idle problem
Try giving the carbs a good balance to give you a base setting to work with. :thumbup:
