missfire
missfire
Hi all just purchased 98 firestorm and seem to be getting a misfire when holding revs bike pulls well but when holding constant revs it seems to misfire and I can feel it through the tank changed plugs and filter balanced and cleaned carbs but problem persists could this be a problem with coils and leads thanks in advance bert
Re: missfire
Sounds like Carb Fart, they all do it to a certain extent, basicaly a backfire through the carbs into the airbox.
Check your TPS setting with a meter & try to get it adjusted to as close to 500 omh's as poss.
viewtopic.php?f=31&t=29429
Re: missfire
Tps done last night seem to help idle and low speed riding but still getting same symptoms when riding harder pulls well but when holding throttle or slacking off throttle a little it seems to misfire or surge can also hear what i think is the cam chain slapping . Manual tensioners where fitted and timing was checked any help would be much appreciated thanks
