fooking storms
fooking storms
yellow one runs fine, leave it for 4 days and hit the starter and nothing :redface .
fuses all good, all connections seem fine behind the clocks. main fuse ok. but engines not turning over unless i cross the starter solenoid ., no clicks from it mind you when i hit the starter button, new battery aswell full of charge.. also dont seem to be getting a spark.
this firestorm thing is wearing very fooking thin with me off late.
Re: fooking storms
fabiostar wrote: Sun Apr 28, 2019 1:27 pm yellow one runs fine, leave it for 4 days and hit the starter and nothing :redface .
Starter button thrown a wobbler ? Frank has a couple in stock, if you try your blue bikes one & thats the cause... Be happy to send one over...
Whole bike teaching you a lesson for selling it previously ?
Re: fooking storms
MacV2 wrote: Sun Apr 28, 2019 1:33 pm
god knows mac, i had a look but it seems fine, its been case into the corner , i dont have the stomach to work at these bikes anymore :thumbup: :thumbup: .
Re: fooking storms
iv also lost my neutral light atm ?
so the easy fix atm is, sorn the fooker off the road, job jobbed :D
Re: fooking storms
Is it in gear? Have you checked side stand switch?
Hope you get it sorted soon
Re: fooking storms
Duffy1964 wrote: Sun Apr 28, 2019 8:17 pm Is it in gear? Have you checked side stand switch?
Hope you get it sorted soon Image
ay checked but cant see anything outa the normal.. for the time being its been chucked in the naughty corner..
Varastorm
Re: fooking storms
Post by Varastorm »
Duffy is on to it :thumbup:
I had the same issue yesterday & it was in gear :roll: I gave up as well, the rage was intense.
I was concentrating on the temp gauge at the time & knocked it into gear whilst goofing around.
Anyone know if they lose all its oil if the cooler pipes are removed whilst it's upright?
Re: fooking storms
Varastorm wrote: Sun Apr 28, 2019 9:03 pm Duffy is on to it :thumbup:
iv checked by... kicking it a few times :clap: def not in gear...
as for the oil pipes i changed mine and lost a bit of oil but not a lot.
Re: fooking storms
One is above the oil level and one is below the level when sitting upright :thumbup:
Varastorm
Re: fooking storms
Post by Varastorm »
Ok, thanks for the info on oil loss :thumbup: Cheers guys :D
Deffo in gear Fab, check again :wink:
Re: fooking storms
well i got my nautral light back :thumbup: . after much cleaning of connections on the second attempt i shorted out the nautral switch and she fired up,, sometimes/always its the last thing you try so the old girl seems to be running the best again.. :thumbup:
Re: fooking storms
fabiostar wrote: Mon Apr 29, 2019 9:20 pm well i got my nautral light back :thumbup: . after much cleaning of connections on the second attempt i shorted out the nautral switch and she fired up,, sometimes/always its the last thing you try so the old girl seems to be running the best again.. :thumbup:
Good man, well done Rob :thumbup:
Re: fooking storms
sirch345 wrote: Tue Apr 30, 2019 10:06 am
at least the yellow ones sorted. the other one :eek2 . not even going there :deadhorse1: :deadhorse1: :deadhorse1:
