Petrol tank removal
Pendingfirestorm
Petrol tank removal
Post by Pendingfirestorm »
Afternoon all
I am going to strip and repaint my petrol tank.
How easy is it to remove and put back?
I have a 2000 plate.
Have searched the knowledge base but couldn’t find anything.
Re: Petrol tank removal
It's just two bolts up front 8mm - then a 10mm at the back running hozintal - unplug fuel sender connector again at the back
Lift tank up at rear , prop up carefully, take photos / mark hoses where they came from 2 fuel, 2 drain & 1 vacuum
Job done - to put back on reverse of above - special note watch where you put the vacuum hose back on.
Downloadable PDF Service Manual is in the Knowledgebase section.
Pendingfirestorm
You make it sound easy!!
I’ll give it a go and let you know how I get on.
It is easy. It's harder to ride a bike than remove the tank :lol:
Don't loose your little rubbers along the side rim at the base of the tank. You will want to remove the petrol cap for painting. It's only three bolts that hold that in place. The others are smaller and only there for show.
EJamesJr
Post by EJamesJr »
VTRDark wrote: Sat Aug 11, 2018 1:02 am It is easy. It's harder to ride a bike than remove the tank :lol:
Can someone post a pic of the location of the rubber bits on the bottom of the tank? I had one (should there be two?) hit the floor the first time I removed the tank. I put it back where it looked like it was but it doesn’t touch anything. I set it aside. Looked in the service manual but it’s not mentioned. Thanks
sj eb 2.JPG (63.23 KiB) Viewed 2395 times
Obviously the same on both sides, try a little dab of glue to hold in place...
EJamesJr
Post by EJamesJr »
Thanks MacV2. That makes a lot more sense than where my one is located (see pic). The other was not there. I will relocate the one and see about getting a second one ordered.
