I am having my cct changed and valve clearances done.
I was with my mechanic friend as he done them and he done the rear first then as he went to do the front we noticed the cap missing off the cct.
would this of been left off for a reason or just someone before had forgot it?
thanks
not the normal question about cct
Re: not the normal question about cct
Check it not still in the cyl block, I had to fish one out with a magnet once
- bazzashadow
no
had a very good look and got a panic on
but when looking at the end of the tensioner you can see a big indent of where it has sat on the guide
It's not really a problem, well maybe long term but the spring would fail before it would wear through When I got mine it the previous owner had a Big well known Honda dealer change them, when I got it I stoppered them and the caps were missing, you don't get them with new ACCT's you have to swap them, they didn't. No problem for me as I had spare caps from doing MCCT's for customers.
Assuming your changing to Manual's there's no problem, if your putting new Auto's in then You should really get a new cap.
It's not at all times unusual.
Oftentimes people just try to replace like for like and don't remember to swap the cap over.
Still, you fitted manuals, didn't you? The design on manuals doesn't need a cap.
You only need a cap if you're doing the stopper mod, or, if you love taking chances, replace with another standard one.
The cap is important as it lets the tensioner slide against the back of the tensioner blade.
If the rubber end is trying to slide in the blade, even lubricated with oil, it won't, especially when under tension from the spring.
- bazzashadow
thanks for the replies
for my sins I am fitting autos and I will be getting a cap
I have now put my tin hat on
Why?bazzashadow wrote: ↑Mon Aug 07, 2017 8:55 pm thanks for the replies
There is no good reason not to fit manualsMacV2 wrote: ↑Tue Aug 08, 2017 7:22 amWhy?bazzashadow wrote: ↑Mon Aug 07, 2017 8:55 pm thanks for the replies
- bazzashadow
Don't ask me
I have had enough of bikes and cars at the mo
I have one bike out of 4 round mine that works and that is the one I borrowed.
My car is pulling to the left
And my new shotgun has gone rusty
So not a good week
So not a good week
