screeching noise on starting
Keef
Post by Keef »
ok,so I just bought a Storm/joined forum,but have got a starting problem.
sorry,I know this has been discussed before,and I have searched for it here,I realise it is almost certainly the starter transfer gears,but,has any one got any good ones to sell,or point me in the right direction for a set,also any one who can help me fit them,west mids,or nearish ?
HELP ! :oops:
Keef
Re: screeching noise on starting
Post by Keef »
so....
decided to strip it anyway,er,just to have a look,as you do,had to fabricate a flywheel puller (which took longer than the rest of the job) pulled it all apart,call me mr Impatient,if you will,but thought if the transfer gears are worn anyway,may as well try the welding them up trick.
So that's what I did,all back together no probs,apart from needing a new generator gasket,tested,starts well,no screeching.
Still after a set of good transfer gears,if anyone's got some to sell,as I would prefer it to be how mr Honda intended :wink:
I might have a set !
I might be striping my motor down on Saturday ,I'll let you know
Keef
Post by Keef »
lloydie wrote:I might have a set !
I might be striping my motor down on Saturday ,I'll let you know Image
ooh ! excellent thank you,pm me if you have some. :thumbup:
I have a known good set from an engine I was using.
20 posted.
tony.mon wrote:I have a known good set from an engine I was using.
20 posted.
Happy days Image take Tony's ImageImageImageImage
Keef
Post by Keef »
20 posted.
spot on mate,can you pm me your details,to sort ?
cheers
Keef.
how did you manage to get them out of the engine?
fabiostar wrote:how did you manage to get them out of the engine?
https://www.vtr1000.org/phpBB3/viewtopi ... rag+clutch
bazza696
Post by bazza696 »
Does the bike have manual tensioners in it, when changing mine, it screeched when adjusting them to tight.
Keef
Post by Keef »
removed starter,gen cover,generator,removed tensioner slider bolt,slid tensioner down,removed gear spindle,gears lift out ! :wink:
Keef
Post by Keef »
bazza696 wrote:Does the bike have manual tensioners in it, when changing mine, it screeched when adjusting them to tight.
no,not yet. cured now,so defo gears.
i was was wondering as mine had the same problem a few years ago but i give it to somebody else incase i done more damage than good.
Keef
Post by Keef »
20 posted.
cheers
Keef.
not sure if you can pm me ?
I can't send,but may be able to receive messages ?
