I've got a wobble on
Since owning bike I've never been too confident getting the bike over in bends due to what I can only describe as a slight wobble through the bike itself.
I'd put it down to the 10 year old tryes on it, not worn just bike not been used in years.
I got both wheels powder coated and fitted new wheel and sprocket bearings and had 2 new tyres fitted.
While out this morning it's still happening, even though I'm still taking it easy due to the new tyres. I enter and exit bends and get a slight wobble which is most offputting to say the least. Accelerating and breaking hard gives no problems.
Any advice as to the best places to start stripping down as I won't be using it much over the winter.
One of my projects next on list was to strip and grease the swingarm, could anything there be the problem?
On a stand there is no movement at all grabbing the tyres and trying to rock the wheels side to side at various points.
Thanks for any info.
Re: I've got a wobble on
Head bearings..?
Always worth stripping & checking the rear linkages any way.
Has the bike got a massive shock spacer on it...should be max of 6mm only. Have a look at the top of the shock, peer in through the side of the bike, as standard the top shock mount should be touching the frame. If it has a spacer in there you will see it quite clearly.
Or the forks pulled through the yokes. As standard the top of the forks should be level with the top of the clip on. If it's been pulled through (up...therefore lowering the front...) there will be fork showing above the clipon...5mm max is advised...
Tyre pressures?
headbearings? Too tight / too loose
Engine mounts? Esp as the engine is intergral part of the frame.
Swing arm bearings?
Suspension shagged?
Swing arm bearings?
Suspension shagged?
Head bearing as first check, then if the trident work then adjust the damping on the forks, make a big adjustment to see if it has any effect, i.e. go for almost fully in. then if that stores the wobble, then adjust back towards your original setting
I can't see anything looking in, could there not be one on?MacV2 wrote:Head bearings..?
Also the shock is set to the lowest setting (looking in through frame).
CheersWicky wrote:Tyre pressures?
Swing arm bearings?
Suspension shagged?
I'll work my way through that lot, only thing I'm certain of is the tyre pressures are spot on.
Ok thanks, all the possible causes mentioned should keep me busyAMCQ46 wrote:Head bearing as first check, then if the trident work then adjust the damping on the forks, make a big adjustment to see if it has any effect, i.e. go for almost fully in. then if that stores the wobble, then adjust back towards your original setting
There's also the little screw adjustment for rebound right on the bottom of the shock right hand side of bike.Also the shock is set to the lowest setting (looking in through frame).
This may be of some help when it comes to setting up suspension thanks to Pete. It's the most informative post he's ever written
http://www.vtr1000.org/phpBB3/viewtopic ... on#p352880
- firestorm_al
- Site Admin
- Contact:
Check that your front brake disks aren't warped.
Al.
Al.
cybercarl wrote:There's also the little screw adjustment for rebound right on the bottom of the shock right hand side of bike.
Thanks carl that's something else to read up on
Disks seem fine, it's mainly bends that it happens, sort of a combination between a wobble through the bike and feeling like something is loose, straight line accelerating/brakeing is fine.firestorm_al wrote:Check that your front brake disks aren't warped.
Al.
I managed to get out for the 1st time this week.
I previously jacked the bike up and tried to see if there was any movement in head bearings, non detected although they could be too tight but bars turn free enough with no notching.
I tried various settings on the fork dampers but during the ride the wobble was still there.
Tyre pressures all ok at 36 front and 42 rear.
I'll eventually work my way through everthing else that was mentioned, but 1st think I'll just read up get the head bearings changed for now.
If you're going to replace the steering head bearings, you just as well replace them with taper roller bearings, although don't use the recommended torque settings for standard s/head bearings, as those are for original OEM ball bearings type.john306 wrote:I managed to get out for the 1st time this week.
All Balls in this link will do the job:-
http://www.ebay.co.uk/itm/ALL-BALLS-STE ... SwPe1T~zLd
It might pay you to have a look at yours first, you may find a previous owner has already changed them for taper roller bearings, in which case I doubt they'll be worn out,
maybe a bit of a curved ball. but iv tried those tyre pressures, and on long sweepers when im giving it a little it was like riding a sofa. the wiggle started at the front and worked the length of the bike. i settled on 32f 34r and its a lot better, infact a different bike to ride.john306 wrote:I managed to get out for the 1st time this week.
I'm sure it was mentioned they have taper head bearings already fitted. Will these generally last years and years then considering the bike has covered very very little mileage over the last 10 years?sirch345 wrote: If you're going to replace the steering head bearings, you just as well replace them with taper roller bearings, although don't use the recommended torque settings for standard s/head bearings, as those are for original OEM ball bearings type.
Ok thanks, I'll try a lower pressure and see what happensfabiostar wrote: maybe a bit of a curved ball. but iv tried those tyre pressures, and on long sweepers when im giving it a little it was like riding a sofa. the wiggle started at the front and worked the length of the bike. i settled on 32f 34r and its a lot better, infact a different bike to ride.
