Anyone know what the length of std bars is?
I've got a suspicion that my bars have been cut down and I'm being lazy rather than stripping grips off to check for cuts.
What should the bar length be?
- freeridenick
Re: What should the bar length be?
The actual bar length is 194mm as below. This h/bar is from the earlier 16ltr fuel tank model, and IIRC the later bars are slightly shorted due to the angle being less so that the overall width of the bars are the same for both models.
- freeridenick
Ta.sirch345 wrote:The actual bar length is 194mm as below. This h/bar is from the earlier 16ltr fuel tank model, and IIRC the later bars are slightly shorted due to the angle being less so that the overall width of the bars are the same for both models.
