CCT WOES, I tried, I conquered with help
Hey guys, I went ahead and tried to fit manual ccts as some of you know. Unfortunately im stuck to a point where I dont want to touch it anymore. I dont know how to set the adjustment on the rear cam chain (havent got as far as the front one yet) and I dont trust what iv done. I need rescuing big time. I dont know what im doing and I just cant risk messing it up. Where do I go from here? I need somebody that knows what to do to carry on.
I know I shouldnt of attempted it. I just dont trust myself.
Re: CCT WOES, I tried.
Where abouts are you? I'm sure someone would be close.
Mickleover in Derby mate.
Good morining gentlemen,
Having slept on it, I still feel the same about it and have decided I need some help.
I know its really cheeky to ask but if anyone fancies rescuing a damsel in distress from derby then I will be more than happy to pay with money, beer or hugs.
Sorry to ask guys but I dont feel comfortable continuing. And my garage is a mess. OCD may kick in at any time.
Thanks Andy.
Thanks Andy.
Hi Andy, are you following the cct guide on the forum?
If I was close I'd come and help
Can you describe the point you are currently at with the cct installation? We could talk you through it bit by bit
Jamie
Hi jamoi,
I have the rear cct in and am trying to adjust the free play in the cam chain. I just dont understand how to measure it. I cant see how best to measure between 7-5mm and the vid on the guide doesnt work.
Iv just got a seed of doubt in my mind and I dont feel confident in what to do.
It's quite simple really, don't over think it.
Remove the metal cover located above the chain between the two sprockets, being careful not to drop the bolts in the engine.
Once you have access to the part of the chain between the two sprockets, apply reasonable pressure to the center of the chain (the slackest part) in an up and down motion, using a ruler measure how much the total slack movement up and down in the chain (should be 5 - 7mm total) adjust the cct to achieve the correct total slack.
That's all there is to it
Jamie
Ok well thats what id been trying to acheive, so are you saying that from the highest point of the chain to the lowest point of the chain travel that should measure 5-7 mm? And do you rest the ruler on the piece of metal directly below the middle of the chain?
I suspected this was what to do but im unsure of my own checking and measuring, hence the doubt and the anxiety attack that it was going to turn into a fireball when I turned my back to it!
andy, if you need to talk to somebody over the phone as you do each bit I can PM you a mobile number
Hi amcq, thanks alot for that ill definitely use that if I get stuck, although I am still secretly holding out for someone to help me, another pair of eyes always helps.
I'm not far from you and could pop round and help
Il drop pm with my number
Aha you know what it is black and yellow...black and yellow !!!
fecking love this place for the reasons above. brilliant.
i still havnt done mine and im a scardy cat ffs dreading it but i live in fecking NI so up the creek and no paddle
+1.fabiostar wrote:fecking love this place for the reasons above. brilliant.
I did,nt feel confident enough to do mine either. I have not a lot of time to devote to the bike so I just thought I will balls it up somehow and it will be sitting there in bits when I could be riding it
good luck with getting it sorted however it gets done
- bazzashadow
I`m the same
wish I was on here when Jamie had his garage day
if not to get my cct done or someone to ride my bike to tell me what's wrong with a intermitted misfire I have
to see jamie`s mum would of been great
And the local church worshippers didn't turn up for that one either.wish I was on here when Jamie had his garage day
O Lordy we praise the Firestorm. God give us speed.
