New boots too big
New boots too big
OK did a 60 mile ride yesterday after getting the bike back together. The bike is running sweet however, my new boots are not happy with the gear shift. Being a lot wider on the toe area I am finding the gear shifting up much harder, I feel that I need to raise the gear shift up so I can fit under it better. Could someone run me through the adjustment procedure if it is possible on standard resets.
Re: New boots too big
To adjust the height of the gear change lever you need to adjust the length of the joining rod, the rod that goes between the two rose joints. You need to slacken off a lock nut at each end of the rod (remembering one end has a lefthand thread IIRC I can't remember which one of the top of my head). Turning the rod one way will raise the gear change lever, the opposite way will lower it. Once you have altered the height remember to re-tighten up the two lock nuts.
Your memory is not that bad as you are indeed correct.remembering one end has a lefthand thread IIRC
While you at it you may want to move the linkage arm that attaches to the spline on gearbox 1 notch clockwise to give yourself a shorter shift. This helps with gear changes.
I had the same issue with my new boots which were wider / bulkier in the toe area tweaking the position of the gear lever sorted it.
I've now gone all European and bought a KTM Superduke GT and Aprilia RSV1000R ,
Storm is now gone . .
Looking very nice mate, well done.
Missing a fairing bolt !!!
But not bad for a blue one I suppose :-)
There's a lot of Yellow ....And what's that sticking out between the clutch slave and the sidesatand switch wire? She's sounding good.
(:-})[/quote]
I have no idea but it is a sensor of some description. Cannot even find it in the Haynes manual.
(:-})[/quote]
You should have the neutral switch wire connected there. Have you not got a neutral light on the dash.
Yes neutral light is working fine possibly due the fact this is an F2 model. It is the neutral switch 9.18 image 22.2 Haynes manualcybercarl wrote:You should have the neutral switch wire connected there. Have you not got a neutral light on the dash.
Well that was my first thought too. Weird....you should trace your wiring, see if you can find the plug, and where's the neutral lights getting it's power from.possibly due the fact this is an F2 model
Trust the Man Dog to notice a bolt missing
She's looking good D/E
Have you tried the suggested settings for the gear lever yet?
Chris.[/quote]
Done check the gear lever in the top photo one notch clockwise
BTW the fairing bolt is not missing it just had not been fitted as I had to do another fixing on the water pump
Chris.[/quote]
I can see that, I was wondering if you thought it helped perhaps you've not road tested it yet,darkember wrote:Done check the gear lever in the top photo one notch clockwise
