Frame Headstock bearing seats damaged?
Re: Frame Headstock bearing seats damaged?
AMCQ46 wrote:
tony.mon wrote: Tue Apr 03, 2018 8:46 pm
Duffy1964 wrote: Tue Apr 03, 2018 6:15 pm Sounds like you have cracked it Al well done fella Image
No, it sounds like he HASN'T cracked it!
my thought exactly :lol:
ImageImageImage Well done Mr Mon Image
longer test ride today and the clunk is starting to return :( ... not as obvious on heavy braking but medium braking when rolling over poor surfaces you can really feel it
the castle nuts haven't moved, as I marked their position, so I will tighten a bit more and test again, I will also do the front wheel bearings just in case
AMCQ46 wrote: Fri Apr 06, 2018 7:53 pm longer test ride today and the clunk is starting to return :( ... not as obvious on heavy braking but medium braking when rolling over poor surfaces you can really feel it
Oh no not again.
Probably worth trying a new set of wheel bearings I agree, do keep us posted.
Fingers crossed that does the trick,
Hope you get it sorted soon Al
It’s not that sizeable, loaded wallet moving about when you brake is it Al? Try sending all your cash to me and then go for a test ride and see if it improves! I’ll send it back after, honest!
Kev L wrote: Fri Apr 06, 2018 10:22 pm It’s not that sizeable, loaded wallet moving about when you brake is it Al? Try sending all your cash to me and then go for a test ride and see if it improves! I’ll send it back after, honest!
good thinking .. a large wad is in the post as we speak :D
I know you too well mate! You’re not allowed to send used toilet paper through the UK postal system and I shall be reporting you for your disgusting behaviour! Same old faeces! :lol:
Is it your oversized knacker banging the tank under deceleration?
Try tightening your undercrackers.
popkat
Post by popkat »
Here's one to try. On some Yamaha fazers and R1's the fork seal can move down a little, it's still retained by the clip but the washer above it is then loose and can make a clonking sound over bumps and when braking. the cure is easy, remove front mudguard and lower the fork dust seals, get a fork seal driver and tap the seal up, shouldn't take much pressure to do it. Probably not the issue here but if you have the tool it's easy to do.
dear god that front end is fighting you all the way :eek2 :eek2
short update.
I have got the steering head bearings set now so there is no free play and it is nice and stable in a straight line :D
I still had the judder under med speed, med pressure braking, that I can feel through the forks, but now the bearing are tighter it is not causing the knocking, but is still very obvious. and effected any kind of trail braking.
so I did the trick with cleaning the bobbins by spinning them and flushing with brake cleaner ... no improvement
so I put a clock on the disks and one was approx. 0.005" and the other was 0.010" total runout, in theory inside the factory limit for a Storm, but still not too good.
SO
I splashed out on a set of Galfer discs and fitted them on the night before the trip up to Yorkshire.... and the good news is the judder is gone :D
so I think with stiffer forks and much stronger brakes, the judder from a bit of disk runout creates a very strong force, and this made the smallest clearance in the brgs clunk badly.
so Good news is we can close this thread and I don't need a new frame
E.Marquez
Post by E.Marquez »
So you only feel / hear it under breaking?
Perhaps it is, the brakes?
Pulled my hair out diagnosing a "click/felt clunk" when applying the brakes.. Felt like head bearings ...wasn't.
Felt like loose calipers...wasn't.
But during caliper inspection I noticed tell tail signs of wear, movement, brake pads in the caliper... The Pads were moving...forward when brakes applied Hear click, feel clunk...off brakes and the slight drag all disk brakes have by design, gently move them rearward again...till next time on brakes.
Very slow engagement of breaks and barely noticeable click felt.
Hard on breaks and you could hear it in my bike next to him while riding. ..
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
AMCQ46 wrote: Thu May 24, 2018 5:49 pm short update.
SO
Thanks for the detailed update Al, good to hear all is now well................eventually :wink: :lol:
Rather ironic how IIRC you ended up replacing the front disc's when you did the front brake caliper upgrade on the OEM Storm forks,
Good memory Chris, that was true.... In fact Cheekykev and I were talking about that as he hit the same problems this month when he fitted the CBR calipers
AMCQ46 wrote: Sat May 26, 2018 6:43 am Good memory Chris, that was true.... In fact Cheekykev and I were talking about that as he hit the same problems this month when he fitted the CBR calipers
Well I never, it makes you think what is causing that to happen.
I have only ever heard or read about yourself and now Kev having that issue,
