Scottoiler
Bikerbob
Scottoiler
Post by Bikerbob »
I have an electronic version that is fully automatic , but it is showing a blue light on the screen. Stays on ,but should not ,no idea if its a problem ,no idea how to stop it.
Re: Scottoiler
Bikerbob wrote: Tue May 05, 2020 12:03 pm I have an electronic version that is fully automatic , but it is showing a blue light on the screen. Stays on ,but should not ,no idea if its a problem ,no idea how to stop it.
Ya best bet is to contact Scottioler themselves...Doubt they will be open but someone might be working remotely checking emails...
You say North Kent ... where abouts ? I'm in Grain, Tony M is in North kent as well...
We are a right bunch of Kents...
Bikerbob
Re: Scottoiler
Post by Bikerbob »
I'm in Bromley , West Wickham .
Re: Scottoiler
Bikerbob
Re: Scottoiler
Post by Bikerbob »
Nah!!,that's why I asked you brainy lot. Son says it did not do that on his MT10.
Re: Scottoiler
Bikerbob
Re: Scottoiler
Post by Bikerbob »
Thanks guys,but no answers there . Perhaps an E-mail may find a human.
Re: Scottoiler
http://kbvps.scottoiler.com/assets/Gene ... ide-v1.pdf
Flashing LED is to show it is pumping.
The flow rate will default to OFF (Ø) when oil reservoir is empty.
The system needs refilling, priming and the flow rate reset.
Bikerbob
Re: Scottoiler
Post by Bikerbob »
No flashing ,was working fine, just the screen illumination should go off when the bike is parked , left for months it will flat the battery. Had to disconnect but that means a full reset every time I want to ride. Not practical. Back to EP90 and a brush!
Re: Scottoiler
EP90 rules.
I doubled the life of my chain using that and a manual “Loobman” which used to cost about £15.
Well worth seeing the if they are still in business after all this malarkey
I’ve used every type of lube under the sun over the years and it still works the best
Re: Scottoiler
Pete.L wrote: Wed May 06, 2020 7:21 pm EP90 rules.
Well worth seeing the if they are still in business after all this malarkey Image
I’ve used every type of lube under the sun over the years and it still works the bestImage
pete :lol: that last line just sounds SO wrong :lol: :lol: :lol:
Re: Scottoiler
