guys need a question answered for a friend of mine before he takes the plunge.
a vara ,does a vtr engine fit straight in? as in straight bolt in or is there a difference in the mounting points? hes not worried about pipes or carbs of electrics, just if the engine fits in the vara frame
vara/storm mate up
vara/storm mate up
Re: vara/storm mate up
Rob, PM Varastorm if you've not already,fabiostar wrote: ↑Tue Nov 05, 2019 11:18 am guys need a question answered for a friend of mine before he takes the plunge.
yeah chris i just sent him a wee pm, iv a friend wanting to do the swap but not just sure if its a straight swap or notsirch345 wrote: ↑Tue Nov 05, 2019 11:00 pmRob, PM Varastorm if you've not already,fabiostar wrote: ↑Tue Nov 05, 2019 11:18 am guys need a question answered for a friend of mine before he takes the plunge.
Yes, the crankcases are identical.
That's why you can drop a set of Storm gear shafts into five-speed Vara case set (the early ones were 5 speed), or swap the cams and pistons.
If you change the exhausts as well, they will need custom mounts as the can mounting points are different.
But the mounting points for the engine to frame are the same.
happy days tony thats the very jobtony.mon wrote: ↑Wed Nov 06, 2019 9:55 pm Yes, the crankcases are identical.
Or was it your accent and you fancied a ride-out with a Varadero owner?
theres a very sick man over here building a rather fast vara atm
