I agree with your gearing theory. I tried one tooth down on the front years ago and it just doesn't work, the gearbox ratio's throw a curve as 5th and 6th especially are long, but the others are not. I then changed back and went just one tooth up on the rear, not a massive difference felt a little more perky but really was hardy anything over my mates one which was stock gearing, worth a try but it will put the speedo out a bit. on the plus side you'll get closer to 180mph on the clock maybe 160
Almost had a fault free ride.... almost !
Re: Almost had a fault free ride.... almost !
It’s just the fact it’s strugling to redline in top. I’ve gone one tooth smaller on the front on a few bikes. Including my st1050.popkat wrote: ↑Tue Jun 25, 2019 9:56 pm I agree with your gearing theory. I tried one tooth down on the front years ago and it just doesn't work, the gearbox ratio's throw a curve as 5th and 6th especially are long, but the others are not. I then changed back and went just one tooth up on the rear, not a massive difference felt a little more perky but really was hardy anything over my mates one which was stock gearing, worth a try but it will put the speedo out a bit. on the plus side you'll get closer to 180mph on the clock maybe 160
It worked bloody fantastic on that bike. But with the VTR it’s just a riding thing. The st pulled much harder in top. I would perhaps go two teeth bigger on the rear but I’m ashamed to say I’m also thinking of fuel consumption. It’s heavy enough. But I want a better ride. I think one extra tooth on the rear is a decent compromise for road use. I am supposed to be growing up an slowing it down
Over all.... it really does feel rather flat in top. It’s deffo over geared slightly. I would venture a guess Honda tried to help the poor fuel consumption as 6th seems almost like overdrive. I hardly used 6th gear last Sunday and it was a far more exciting bike lol
Of course..... riding this way is a real option too. That would leave me with an overdrive system.... which is no bad thing on a VTR
In fact I shall experiment with this a little more. Because riding like that felt good. Like in it being a different bike kinda good.
I know I was hitting speeds around 120-130 mark. But I was not thrashing it at all. Around 8500 rpm mark. This tells me 150 should be in easy reach even in 5th. Hmmmmm I could be onto sumit here.
In fact I’m now going see just what it will do in 5th rather than 6th.
Is it Sunday yet
Update.... although I’ve posted my findings on another thread
Well I did my experiment today. I must say I was a bit surprised. As in better than I expected.
Opened it up in 5th gear ! Managed to hit 10,000 rpm about 5mm into the redline, without too much of a problem.
Speedo was reading 155
The bike is actually faster in 5th than 6th lol.. not only that.... it got there a darn sight faster than rolling on in 6th.
So I’m leaving my gearing stock. It’s heavy on fuel and having that 6th gear overdrive helps a lot
