headstock bearing numbers
haynesjones66
Post by haynesjones66 »
anyone know the honda part numbers for upper and lower headstock bearings please?
Re: headstock bearing numbers
If you're thinking about replacing the steering head bearings, tapered roller bearings are a better option than OEM ball bearing type bearings. The reason being, tapered roller bearings have a bigger contact surface area so last longer, and should need less adjustment once set correctly.
If you are replacing the steering head bearings with tapered roller bearings, don't go by the torque figures in the workshop manual for the castellated nuts,
haynesjones66
thanks for that info, gents. i was kinda hoping that the bearings would match my 78 cb750 but it's definitely a stem swap now. planning on grafting a vtr front end on my phil read rep. easily done, just hoping to make my life easier!
