Hi guys , just joined the forum , backfire problem
Donneboy1
Post by Donneboy1 »
Hi guys , new in here , ride is 2001 Storm . I have a problem on start up , happens hot but more often cold . Bike cranks over well but doesn't fire , eventually firing and detonating a huge backfire through the exhaust . New air filters ( main and subs ) new plugs , drives me and my neighbours nuts . Any ideas on problem greatly received .
Re: Hi guys , just joined the forum , backfire problem
once it starts does it ride ok?...
is the vac pipe on the correct takeoff on the tank?..
popkat
Post by popkat »
Timing 1 or 2 teeth out.
Valve clearance too tight.
Tell us some more about the bike, mileage, services done, has it had the cam chain tensioners replaced ?
Don’t use choke until it’s running , only a tad of throttle
popkat wrote: Sun Oct 07, 2018 10:06 pm Timing 1 or 2 teeth out.
Also was this happening before you replaced the air filters and plugs :?: or since,
