Dead on the key......SORTED
TaxiDriver
Post by TaxiDriver »
The bikes been running faultless all this time,starts up straight away every time.
Booked in for suspension set up today and its dead on the key!!.
Battery fully charged,fuses all ok,just totally dead,it looks like its had the reg/rec replaced.
Any quick thoughts as to why its dead,maybe something simple before I have to rip it apart.
Re: Dead on the key......
TaxiDriver wrote: Sat Jun 02, 2018 9:30 am The bikes been running faultless all this time,starts up straight away every time.
Any clicking from the starter relay ?
I had an issue with a non starter, changerd starter motor, cable, relay...turned out the battery had dropped a cell...Showed volts but not enough amps to turn it over...
Did you check the main fuse in the starter relay ?
TaxiDriver
Yes Mac,checked main and all other fuses.
There is no sign of life,no neutral light or anything.
Neutral switch, sidestand swich, is the run button on or just saying it's on.
TaxiDriver
There's just no power going anywhere....... 8O
TaxiDriver
SORRY............have to stand on my head to read the Optimate......1.1v oops.
TaxiDriver
Re: Dead on the key......SORTED
So just reached full charge after all this time......mmmm have to keep an eye on that bugger.
