Water Pipe
carmanbikes
Water Pipe
Post by carmanbikes »
Hi everyone hope your all well and good, Would anyone know the size of the water pipe that runs from the top of the water pump to the carburettor, looked on the fiche but can't find it. tia :thumbup:
Cadbury64
Re: Water Pipe
Post by Cadbury64 »
The parts fiche gives a specific part number, not a diameter. You probably need to measure one of the spigots on the carb to work out what size tube it is.
carmanbikes
Re: Water Pipe
Cadbury64 wrote: Sun Mar 18, 2018 8:00 pm The parts fiche gives a specific part number, not a diameter. You probably need to measure one of the spigots on the carb to work out what size tube it is.
Can't even find a part number :redface
carmanbikes
Re: Water Pipe
On the Ron Ayers fiche I look at the water pump cover and it says E18 but no part number :oops:
carmanbikes
Re: Water Pipe
sorted thanks think it's 7mm :thumbup:
