Never turn your back on a welder
TaxiDriver
Post by TaxiDriver »
Because.......
Re: Never turn your back on a welder
Unless I'm missing something not the end of the world to sort out with a Dremel or similar tool. May be the threaded bar could have done with being a little longer, that would have most likely avoided the over-spill of the welds.
At least you've got them done :thumbup:
TaxiDriver
No,what I'm getting at in a lighthearted way is that where a couples of tacks
would of sufficed,we seemed to of gathered more weight.....
E.Marquez
Post by E.Marquez »
TaxiDriver wrote: Sun Mar 18, 2018 2:26 pm No,what I'm getting at in a lighthearted way is that where a couples of tacks
Well lucky for you your welder knowns better :mrgreen:
Those mounts take a lot of force at times...a "couples of tacks" is not the better solution.
So be happy for the "mistake" :thumbup:
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
TaxiDriver
I aint' planning to sit on it........... :lol:
E.Marquez
Post by E.Marquez »
TaxiDriver wrote: Sun Mar 18, 2018 2:45 pm I aint' planning to sit on it........... :lol:
Good, though not what i had in mind..
In a perfect wold the bike goes up cleanly and evenly ...... but that ain't reality for every time.
That time the bike gets levered up on just a single spool at some point, and the odd angle that will happen at....the spool that is not just tacked on will stay welded in place...
Looks good, nice welds, clean up the interference and I think you got a right nice MOD there :clap:
Post event services
Total Rider
grumpyfrog
Post by grumpyfrog »
Wish I could do that.
Very nice job.
I hate standard stands.
Don't hassle me
I'll get there at some time
Out of interest, what is the diameter of the bar that you had welded on? I'm going to do the same and it would help. Bobbins seem to be M8 bolts so I was thinking of 20mm bar.
TaxiDriver
freeridenick wrote: Sun Mar 18, 2018 4:27 pm Out of interest, what is the diameter of the bar that you had welded on? I'm going to do the same and it would help. Bobbins seem to be M8 bolts so I was thinking of 20mm bar.
To suit these bobbins I had to use a 25mm bar and had a flat milled on to help the welder!!
TaxiDriver wrote: Sun Mar 18, 2018 6:02 pm
Thanks bud.
macdee
Post by macdee »
looks like a real good bit of welding
get your file out :P
macdee
Post by macdee »
E.Marquez wrote: Sun Mar 18, 2018 3:09 pm
I concur, that is why I didn't see anything wrong with the welds. As others have already mentioned, a nice bit of welding :thumbup:
I like the the idea of the flat put on the 25mm bar to aid welding.
TaxiDriver
JEEZO..................
